Lost #2 intake lifter...
Old May 10, 2007 | 07:52 PM
Redmanbob's Avatar
Redmanbob
Shop at Dizzy Land expect to have to check the work
Hope the Party's are a great time, and you make them all... No drinking and driving... leave our truck at the first stop you start enjoying yourself at.. (if you drink) BOL..
Old May 10, 2007 | 11:29 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by Redmanbob
Shop at Dizzy Land expect to have to check the work ;)
Yep would have been cool if the parts would have been the right size... i would have been done more than 24 hours ago. Turns out they are actually .030" under, ~3/32" difference between those and my used .060" over rods.
My buddies don't drink or smoke, they've been accused of being Mormons but since they cuss like sailors, I don't think they are. ;)
I'm sure they'd figure out a way to get me a ride but i don't want that... I want to get there under my own FE steam. :)
This doesn't count as the truck leaving me stranded. It wasn't broke down, it was running fine, I just decided to tear into it for the fun of it. :)
In over 32 years my clunky old pickup has never broke down and left me stranded, anywhere, ever. :)
Anyway back to work, got a few things i want to do yet.
Like, one valve was standing pretty high out of 16, I'm fiddling with that.
(#8 intake)
Its lash is .065" (with the shims) and a .060" over push rod and about .220" with a new .030" under rod.
Numbers are starting to look more like it huh?
...now that we know the new rods are .030" under.
The rest on that side are ~.120" to ~1.40" with the shims and .060" over rods.
Thinking about shortening (grinding off and re-polishing) a .060"-over-rod... about .045". :)
A new standard pushrod would give me .120" tho.
Alvin in AZ
Old May 11, 2007 | 06:28 AM
kotzy's Avatar
kotzy
I just dug out an old dusty book 390 calls for 100 to 200 thousands. With that in mind I guess if we pulled a lifter apart I would guess the measurement of the plunger travel would be about 300 thousands, or perhaps more. What you are trying to do with different lenght rod is center the travel of the plunger in the lifter bore. Your 65 measurement was a bit tight removeing the 60 longer rod should bring it to 120. The most important part of the whole operation is having the lifter collapsed and the cylinder being measured at tdc compression when checking the lash. Kotzy
Old May 11, 2007 | 08:33 AM
Redmanbob's Avatar
Redmanbob
One very important part is that the rocker tip rides on the valve tip like it should. If your off center it's gonna make for a wonder wear pattern and last forever and ever...
Leave you stranded ? You must be thinking of one of those other trucks I can honestly say I yet to own a Ford that went out on me when I didnt have it comming
Old May 11, 2007 | 04:13 PM
Alvin in AZ
Kotzy and Bob, the dangged thing is clacking to beat hell.
.100 to .200" lash is just for stock Ford lifters? :)
Just got off the phone with CompCams and he said to measure the pushrod travel, he didn't care nuthing about the lash...
"we want the plunger pushed down into the lifter .030 to .060""
...when the lifter is on the cam's base circle.
"drop the push rod down on the lifter and mark it, tighten down the rocker shaft and mark the pushrod again"
That's about 1/32 to 1/16 of an inch.
There is more difference than that in the valve stem heights.
Hmmm... I need to call them again and find out how much total travel the plunger has, in the lifters I have. :)
This is my first experience messing with hydraulic lifters. :)
I think I like adjusting solid lifters better. ;)
Alvin in AZ
Old May 11, 2007 | 07:40 PM
seetwisted's Avatar
seetwisted
Milling the heads, gasket variations,valve seat and stem variations,etc. etc. The combinations are endless, to get the preload right each valve has to be checked individually. Then the correct push rod for each one to bring the adjustment to the correct tolerences. Yeah...been here too. I figured they'd all be the same and hydralic lifters are supposed to take care of that...right? I ended up with the tighty loosey tappeys...and found pictures of a close to home dummy on the bottoms of my lifters. thats why if your motors going back with the same parts you keep all the parts in order to not mess up the preload...along with other reasons I have laboriously learned. I got mad and went with adjustable rockers and learned more things the hard way. But read here how to fix them all...
Old May 11, 2007 | 07:57 PM
Bear 45/70's Avatar
Bear 45/70
If the heads are done right, all the valve stems will be the same height, so if you check one and it's right, the rest will be too. Only now a days there are very few shops doing it right anymore. Back in the old days in the 60's and early 70's you could send your heads in and get them back done right, now, it's a bigger crap shoot than going to Vegas to win.
Davidwent
Sep 8, 2011 10:08 AM
voodoosurfer
Nov 18, 2008 03:32 PM
welavalle
Sep 17, 2006 02:30 AM
edward327
Bronco II
Feb 20, 2004 05:25 PM
elsmith
Feb 21, 2001 03:30 PM
