1978 - 1996 Big Bronco
Interchange Manual
Old Mar 3, 2001 | 06:32 PM
lilman20815's Avatar
lilman20815
Interchange Manual
Howdy,
Do any of you own the Ford interchange manual ? If so can you tell me if it would help in turning a 351M into a 400M ?
Head numbers, water pumps, and that sort of thing. I'd like to get the most bang that I could get. Thanks.
Old Mar 4, 2001 | 03:07 PM
bb78bronco's Avatar
bb78bronco
Interchange Manual
I dont know the numbers but the 2v cleveland, 351m and 400 m all use the same head. every part is the same between the m's except the crank, rods, and pistons. however, my brother had an m block(351) we took and bored it .030" and bought the pistons for a 400 bored .030". stock the have the same bore just different stroke. then we took the crank and rods from the 400 and put them in the 351. this combo created a 406 inch motor. with a good cam, preformer intake and some head work this motor will run real well. clean up the exhaust ports with a carbide on a die grinder and finish with a stone and flap wheel.
Old Mar 4, 2001 | 03:10 PM
bb78bronco's Avatar
bb78bronco
Interchange Manual
Jonnyuma
Apr 25, 2014 05:56 AM
gomer450
16
Dec 3, 2013 05:29 PM
QH rancher
Offroad & 4x4
Feb 7, 2012 02:58 PM
usmchgb79
Dec 27, 2009 08:08 AM
whisperer
Feb 23, 2004 11:10 PM
