Steering Wheel Interchange-ability...?
Old Apr 22, 2014 | 12:59 AM
Jonnyuma's Avatar
Jonnyuma
At some point, in it's checkered past, my '73 had it's steering wheel swapped out to a 13" box-store POS. I'd really like to replace it with a Ford tiller, period correct is preferred but not mandatory in this case. Can anybody tell me what years I should be looking at? I would assume '73-'79 would be a direct replacement, and that newer airbag units would not. Are the older manual steering pieces a good fit, or is the column different due to safety stuff, ie: collapse-able columns and such that started showing up in the early 70s. I see lots (LOTS!) of 80s F-series getting parted-out so I'm wondering if one of those might work.
Thanx,
Jonny Y
Old Apr 22, 2014 | 08:13 AM
HIO Silver's Avatar
HIO Silver
71 to 77 is correct. A 78/79 also fits.
Old Apr 22, 2014 | 11:18 AM
84espy's Avatar
84espy
Depending on how picky you are, the Econolines also fit and they seemed to be picked through less at the yards
Old Apr 22, 2014 | 11:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Econolines use the exact same steering wheels.
D4TZ-3600-A .. Steering Wheel-Use without Speed Control / Reproduced.
1971/77 F100/350 / 1974/77 Bronco / 1975/77 Econoline.
D5TZ-3600-B .. Black Steering Wheel-Use with Speed Control / Reproduced.
1975/77 F100/350 & Econoline.
1978/79 F100/350's, Bronco's & Econolines use different steering wheels and horn pads.
Old Apr 22, 2014 | 06:47 PM
73axlenut's Avatar
73axlenut
I just installed an 80's ford truck wheel with no modifications. Haven't sorted out the turn signal cancel just yet, and I am not sure about the horn either, still in progress.
It does not match up perfectly at the column either, but you have to really look to notice. Under 50 bucks my old wheel was destroyed anyways.
Old Apr 22, 2014 | 10:28 PM
Jonnyuma's Avatar
Jonnyuma
Okay thank you. Good stuff...exactly what I was looking for.
Old Apr 22, 2014 | 10:53 PM
HIO Silver's Avatar
HIO Silver
Install a jumper wire over the rag joint and the horn will probably work... I'm using a 78/79 wheel on my 73 4x4 and had to do that work-around.
Old Apr 24, 2014 | 04:20 PM
73axlenut's Avatar
73axlenut
Thanks HIO. 73 F250 4x4 with no rag joint. Any good ideas on the turn signal cancel?
Old Apr 24, 2014 | 06:48 PM
HIO Silver's Avatar
HIO Silver
Ah... no rag joint.
Turn signal cancel? Nope... I just try to remember to turn it off.
But that will come to an end soon cuz I recently picked up a 71- to 77-style wheel and pad for low-bucks.
Old Apr 24, 2014 | 07:21 PM
NumberDummy
1966 F100 4WD, 1967/75 F100/250 4WD: Clamp & thru bolt retains lower steering shaft to input shaft of steering gearbox. No rag joint w/4WD until 1976.
Old Apr 25, 2014 | 05:56 AM
bucks77ford's Avatar
bucks77ford
Will the later style steering wheels work on the 73-77 columns with cruise?
hturner12
Mar 30, 2017 06:52 PM
sleddog60
Oct 21, 2013 11:00 PM
ramarado
Nov 28, 2007 10:59 AM
ton10291
Jul 6, 2007 02:12 PM
rhw
Apr 1, 2007 09:18 PM
