OK, then I am confused. The repair manual I have has a section on "Vehicle Speed Sensor" Operation, Testing, and Removal & Installation on Page 4-18 and 4-19. The VSS I replaced is bolted into the top-front of the rear differential and has an electrical connection.
Then on Page 9-33, the RABS "General Information" section mentions a "Speed Sensor", among other things. Is that the one you're talking about?
I guess it depends on which manual you are referring to. The 96-99 Factory service manual has no VSS listing for our trucks. The VSS in post #11 above doesn't exist on out trucks.
That picture looks like the VSS that I bought from the dealership.
I think we've hijacked this thread long enough. My apologies to the communtiy.
I think it is time to say we may have a semantics issue. My repair manual is the Chilton's old number 26666 for the 1997-00 Pick-ups/Expedition/Navigator, not to be confused with the new manual with the same number.
Evidently, Chilton's updated the book and didn't change the book number at the top-right of the front cover.
my 97 had the exact same problem not 2 weeks after i got it back from getting the tranny rebuilt. i thought they just messed my tranny up worse by trying to fix it, turns out it was just that speed sensor on the top of your rear end(pumpkin). the previous owner of the truck tried to spice the wires themselves and over time the wires just came apart. i got my sensor at the tranny shop that i had rebuild mine. it cost me about $85 and i havent had that problem since!
sorry about the double reply. also, follow the wires that run into that sensor to see if you may have a cracked or split wire somewhere near the sensor. mine was split about 1-2 ft up the wire!
thanks guys for your replies, appreciate the info. my fuse hasn't popped in a
few weeks so i guess it worked!on to the next project.i've been reading some forums trying to find the location of cps sensor ,can anyone point me in the right direction.i'ts up front and removing the belt should make it easier is what i got so far . but still don't know what it looks like.also asked my ford parts dept. about a newer cps and they have no clue about it ,wonder if it's up in canada yet. THANKS AGAIAN
Harmonic damper on the front of the engine at about 10 o'clock.
The picture was taken from under the front of the truck looking up.
Thanks to who ever I stole this picture from.
i have a 95 f250 PSD,a couple days ago i noticed it was shifting very hard(AUTO) then i noticed speedo and odometer not working also overdrive light on shifter **** was blinking.checked fuses they were fine.was told it could be a sensor??????
also every blue moon its been stalling without warning but starts up right away
was told cps sensor was the problem. could these problems be connected ???
if not odd sensors going at same time ???? THANKS in advance
My friends tell me to look at my tach.....never at myself in a speedo
oppurtunity is N.O.W.H.E.R.E you decide brother
