speedo and odometer not working
Old May 3, 2007 | 12:46 AM
weezll's Avatar
weezll
i have a 95 f250 PSD,a couple days ago i noticed it was shifting very hard(AUTO) then i noticed speedo and odometer not working also overdrive light on shifter **** was blinking.checked fuses they were fine.was told it could be a sensor??????
also every blue moon its been stalling without warning but starts up right away
was told cps sensor was the problem. could these problems be connected ???
if not odd sensors going at same time ???? THANKS in advance
Old May 3, 2007 | 05:58 AM
Cuda_jim's Avatar
Cuda_jim
Check your RABS (Rear antilock brake sensor) on the top of rear differential, sometimes called VSS (Vehicle speed sensor). Look at the connector pins and sockets for corrosion, bend pins ect. The sensor is likely bad, check wiring first.
Old May 3, 2007 | 03:01 PM
powerstroked162's Avatar
powerstroked162
Ditto
Cowboy Steve
Old May 4, 2007 | 10:03 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
CPS could do this and it sounds like its cheap enough at ford to purchase. Then again, we just had an e-series come in with a "kam memory failure" fault code. I think it said "kam" or "kem"............and it was driving then engine just dies but re-starts. Its the weekend for me so I let the next shift worry about it.
Old May 5, 2007 | 07:14 AM
m14dan's Avatar
m14dan
Most of the ones I've seen where the odo and speedo quit working were internal faults in the cluster itself. We had to send them out for repair. Most of the dealers I worked at had loaners to put in while the original got sent out.
The only way to know will be to have a diagnostic done on it. It could be anything from a sensor to the PCM or even the cluster itself. Lots of things are tied into that system.
Old May 5, 2007 | 07:56 AM
tjbeggs's Avatar
tjbeggs
more than likly the sensors. The VSS for the speedo and CPS for the stalling
Old May 5, 2007 | 02:48 PM
Cuda_jim's Avatar
Cuda_jim
CHECK ODOMETER DISPLAY
  • The trip odometer must be currently displayed for the RESET button to work.
  • If unsure about missing or extra segments, perform the odometer display self test as follows:
    • Press and hold the reset button on the front of the speedometer while turning the key to RUN.
    • Release the RESET button.
    • Press and release the select button. The odometer will begin with all zeroes and step through the display test each time the select button is pushed. Refer to PSOM Display Test Sequence below for exact display.
  • The first digit on the left does not always match the other digits.
    • Key off to exit this test.
Old May 5, 2007 | 10:05 PM
IDMooseMan's Avatar
IDMooseMan
Cuda_jim,
I believe the VSS and RABS are two different components. I replaced my VSS. The repair shop replaced my RABS. The RABS, on my rig, is part of the brake system. The VSS is an electronic component.
I don't see how they can be considered the same item.
Old May 6, 2007 | 05:40 AM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim,
Wanna bet?
This sensor also effects Cruise control because it goes thru the PSOM.
Old May 6, 2007 | 05:45 PM
IDMooseMan's Avatar
IDMooseMan
Well, if you insist.
According to the printed manual that I'm looking at; Page 9-34 shows the VSS located on the top of the differential. They have pictures, too. Then on Page 9-35, to the right of the diagram,
"The valve is located on the frame rail, under the vehicle on the driver's side on the 1997-98 F-250HD, F-350 and F-Super Duty. The valve is located in the brake lines, below the master cylinder.
View G, of Figure 113 shows the location of the Rear anti-lock braking system valve, in the frame rail, not on the rear differential. Perhaps we're talking about two different components.
When my RABS unit was replaced, the technician showed me the until and why it was failling.
Old May 6, 2007 | 07:56 PM
Cuda_jim's Avatar
Cuda_jim
We/you are talking about 2 different components. You had the valve replaced, not the sensor.
Some call the RABS a VSS, our trucks officially don't have a VSS. But it still operates the speedometer. Go to the auto part store and order a VSS and you will get somthing like the picture below.
In the electrical schematic above it shows the RABS (Rear Antilock Brake SENSOR) supplying a signal to the both the PSOM (Programable SPEEDOMETER-ODOMETER Module) and the Rear Antilock Brake Module.
The PSOM supplies a signal to the speedometer/odometer.
The RABS Module supplies a signal to the RABS Valve assembly. The valve you replaced.
Both the PSOM and the RABS Module are located in the dash.
Old May 7, 2007 | 01:59 AM
weezll's Avatar
weezll
hey thanks for all the info guys
i replaced the vss and stil didn't work re-checked fuses and it was popped
put in a new one and speedo worked again .next day i washed my truck when i went to drive it speedo was gone again.so i replaced fuse and presto its woking fine (3days) must be ashort somewhere????? triggered by washing it NO MORE CAR WASHS
Old May 7, 2007 | 06:14 AM
Cuda_jim's Avatar
Cuda_jim
Are you washing the engine when the fuse pops?
If you are just washing the exterior of your truck and popping fuses, you should get it fixed, IMO.
Old May 7, 2007 | 09:57 PM
IDMooseMan's Avatar
IDMooseMan
Cuda_jim,
Yep, we're talking different components. I replaced the VSS (item attached to your comment) myself and a technician replaced my RABS.
BTW...where are you getting this pictures?
Old May 8, 2007 | 06:59 AM
Cuda_jim's Avatar
Cuda_jim
Craig, The VSS I posted won't fit our trucks. The point I was making, "If you ask for a VSS for our trucks, You will get the wrong part." Our trucks don't have a VSS, they have a RABS only, that pulls double duty.
I just steal the picts off the 'net. The technical picts are from my Ford Service manuals on DVD. I have all from 96 to 08. See the link in my sig.
