shift issue.....
Old May 27, 2007 | 10:28 AM
zakquick's Avatar
zakquick
shift issue.....
Hey guys, need your infinite wisdom here. I've got a 97 f350 e40d w/ 185000 on her. I was coming down a steep grade last night, shifting between 1st and 2nd, until i started to near the highway. while rolling to a stop at the sign, i shifted back into drive ( od off) while braking hard right before the stop. the truck stalled outright. no nothin except for a battery light on the dash. wondering if anyone has had this happen, or knows of this issue. Did it one time before on some switchbacks manually downshifting into 2nd with a truckload of people, not good. any input would help me alot!
Old May 27, 2007 | 11:16 AM
Suber's Avatar
Suber
Just before my transmission failed it started to do some very strange things. One that comes to mind was when I was in reverse, trying to back up a very SMALL grade. The engine stalled. Secondly, it started to slam hard when I would push the accelerator from a dead stop moving forward. The problem only got worse even with a fluid and filter change at 100.00 and my labor. I would get it to a tranny shop and have them look at it before you damage it more. BTW, my delay in doing so, cost me a complete rebuild WITH a new tranny housing as my rear bearing seized, fracturing my case.
I would also say that if that is your original tranny you have faired pretty well with that many miles on it.
Old May 29, 2007 | 01:22 AM
mcdavidson's Avatar
mcdavidson
In reply to - Need your wisdom
Not to be stating the obvious (but I will anyways) Did you check your tranny fluid level?... If you have a leak (and it would have to be a pretty sizeable one at that) and lost 3-4 quarts (or more), the tranny will lock and stall the engine (don't wanna tell how I know this....)
aaronsilva90
Jan 19, 2015 12:04 PM
abyars111
Apr 24, 2014 05:35 PM
jptrader207
Sep 2, 2010 07:35 PM
mkdubs
Jan 31, 2010 01:19 AM
dtaube
Jan 10, 2008 04:34 PM
