Check Enigne Light
Old May 3, 2007 | 12:33 AM
ty_97206's Avatar
ty_97206
Check Enigne Light
I have a 1991 F-250 5.8L. The spark plugs were changed and that same day the check engine light came on. The truck still runs fine and nothing seem to be in trouble. I am wondering if anyone else has had this problem and how they fixed it. Thanks
Old May 3, 2007 | 12:43 AM
ksubigbuck's Avatar
ksubigbuck
What kind of plugs? Is it possible that you broke one of those small brittle vaccum lines when changing plugs?
Hunter
Old May 3, 2007 | 12:45 AM
ty_97206's Avatar
ty_97206
I did brake a small red on on the right hand side but i was told it was not a big deal it was for a smog thing (cali built truck)
Old May 3, 2007 | 12:53 AM
Skandocious's Avatar
Skandocious
Well a lot of the emissions equipment has sensors that will throw codes for any kind of change in the operation of the equipment. You should probably pull the codes and see what you get.
-Chris
Old May 3, 2007 | 12:57 AM
ty_97206's Avatar
ty_97206
And how would i pull the codes for my truck?
Old May 3, 2007 | 01:14 AM
Skandocious
There are several methods. If you want to go the cheap/frustrating route you can use a paper clip to jump the pins on the connector and count the light flashers in the cab; the process is laid out here:
http://fordfuelinjection.com/?p=13
If you don't want to do all the work, you can buy an OBDI code reader at an auto parts store for around $30. This is what I did and I keep it in my glove compartment. A very handy device to keep with you on the road!!
Last resort, most auto parts stores will pull the codes for you for free... But thats not a learning experience!!
My bet is that you inadvertently tinkered with something involving the emissions equipment and that is whats throwing a code. The emissions stuff is notorious for this. Good luck!
-Chris
EPNCSU2006's Avatar
EPNCSU2006
http://www.thorssell.net/hbook/eectest.html
You can just skip the analog volt meter/test light (still need that jumper) and watch your check engine light.
Old May 3, 2007 | 01:23 AM
ty_97206's Avatar
ty_97206
Thanks for your help guys
Old May 7, 2007 | 01:46 AM
ty_97206's Avatar
ty_97206
Just wanted to let you guys know what was wrong with my truck.... on the LEFT side of the truck one of the smog wires broke (red one) and then i went to the auto store to get a small rubber tube to re connect it. when I conected the wires and the light has no came on since.... Thanks for your guys help.
Old May 7, 2007 | 01:57 AM
Skandocious
Rock on, glad to hear.
-Chris
CdnSoldier
Jun 8, 2009 09:57 PM
cbbr
May 27, 2006 08:04 AM
bmxerbrett
Jan 29, 2006 08:07 PM
gblakeney
Dec 10, 2001 10:32 PM
rsbeadle
Mar 22, 2001 10:55 AM
