Check Engine Light
Old Jan 28, 2006 | 12:57 PM
bmxerbrett's Avatar
bmxerbrett
Check Engine Light
Does my 87 even have a check engine light? I've seen an emsions light but that is it.
Brett
Old Jan 28, 2006 | 01:05 PM
jhnhardee's Avatar
jhnhardee
it should be o the left right above the wiper control switch and come on for a few sec when you turn the key to acc
Old Jan 28, 2006 | 01:09 PM
subford's Avatar
subford
Brett
I would think that emsions light is the CEL/MIL light.
Old Jan 29, 2006 | 08:07 PM
EPNCSU2006's Avatar
EPNCSU2006
The EMISS light is not the same as the check engine light, and is operated solely based on run time. There is a spot in the dash that says check engine, but the gauge cluster is not wired for the light. It can be wired in, but that might be more work than it would be to check the codes with a voltmeter.
sand1
Sep 2, 2014 09:39 PM
mtgrzlyman
Aug 16, 2004 05:53 PM
gblakeney
Dec 10, 2001 10:32 PM
rsbeadle
Mar 22, 2001 10:55 AM
custodian
1997 - 2003 F150
Jan 15, 2001 05:52 PM
