Ford excursion frame...
Old May 2, 2007 | 10:12 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Does anny body know if the Ford Excursion frame is the same as a ford f250. I need to get a class five hitch but the only thing is they dont have it for the X. I talked to one guy and he said the X is the same as the f 250. Does anny one know if that is true.
Thanks,
Nick
Old May 2, 2007 | 11:01 PM
Monsta's Avatar
Monsta
Sit. Stay.
Frames are different. However, they may be close enough for that hitch to fit. You may need to do some measuring before purchase. Does he have one in stock?
Old May 2, 2007 | 11:10 PM
weekendwarriorfsw32
Master of Strokes
yes its from a web sight though.
Old May 2, 2007 | 11:39 PM
Monsta's Avatar
Monsta
Sit. Stay.
Oh...not sure you'd want to take the chance of ordering it unless he gives you an unconditional money back guarantee.
The hitches are different between the two trucks. Why don't you do some measuring of the drop from the frame, bolt spacing, width etc. etc. and see if he'll compare it.
Why do you need a Class V?
Old May 2, 2007 | 11:50 PM
weekendwarriorfsw32
Master of Strokes
the hitch we have now is faling
Old May 3, 2007 | 12:10 AM
housedad's Avatar
housedad
Take a look at my gallery about the frame. It may help you with the frame differences and similarities.
Old May 3, 2007 | 12:18 AM
weekendwarriorfsw32
Master of Strokes
house dad do you think a ford f 250 hitch will fit my X
Old May 3, 2007 | 12:35 AM
housedad's Avatar
housedad
IMO, no it would not. The frames of the superduties are straight C channel aft of the rear spring hanger. The Excursion frame droops down at a angle and the C channel gets taller. aft of the hanger. you can see that in the side outline drawings in the gallery.
Old May 3, 2007 | 12:37 AM
weekendwarriorfsw32
Master of Strokes
is there a class 5 hitch that would fit
Old May 3, 2007 | 12:38 AM
weekendwarriorfsw32
Master of Strokes
what would happen if i tried to put it in would it fit at all
Old May 3, 2007 | 01:41 AM
Monsta's Avatar
Monsta
Sit. Stay.
Ah ha! I KNEW it was somebody important who put up those differences in pics. I gotta bookmark your gallery now.
Old May 3, 2007 | 08:03 AM
i eat hybrids's Avatar
i eat hybrids
Do you pull that weekend warrior with ur x?
Old May 3, 2007 | 10:21 AM
weekendwarriorfsw32
Master of Strokes
yes i tow it with the 6.0 X. We dont want to have to get a new truck till the bug are worked out
Old May 3, 2007 | 10:24 AM
1 Excursion camper's Avatar
1 Excursion camper
What do you mean "it`s failing"? on mine the hole for the pin is starting to elongate and also the end of the reciever is starting to widen at the top! I do believe class 4 is up to 10000lbs. so is the X hitch a class 5 already?
I noticed when I bought mine at 17k miles and it was never towed with, that there is some play in the tube when you slide in the drawbar! my buddy bought a brandnew 05 and it has the same play and now the same wear as mine with only 4k miles towing 4500 total miles!
Old May 3, 2007 | 10:29 AM
weekendwarriorfsw32
Master of Strokes
That is exactly wat is happing to me the pin hole is getting bigger and it making me nervous . Every tow its getting bigger. And I need the class 5 hitch that is 2 1/2in instead of a hitch that is 2in. The new hitch i want to get is a http://www.reese-hitches.com/WD/dt_tow_beast.html Does anny body anow if there is a class 5 hitch.
Thanks
NIck
