drains in stack pipeing
Old May 1, 2007 | 09:05 PM
  #31
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
ting tings could turn the nicest looking truck into a disgrace.
Old May 1, 2007 | 09:23 PM
  #32
RAMPAGE_F350's Avatar
RAMPAGE_F350
I have a 1/8 inch hole drilled at the lowest point at the 90 degree to flex connection. I vote against the clankers.
Old May 1, 2007 | 11:47 PM
  #33
DM-03_6.0's Avatar
DM-03_6.0
Originally Posted by strokin_it7.3
At least you have some class with the sound of your exhaust. The others are just obnoxiously annoying. Ever hear the exhaust note of a cummins on a dyno? It sounds like a riceburner!
yes the fords always sound good. the cummins always reminded me of a 70's jeep 258ci straigth 6 with the rotted out manifolds haha
Old May 2, 2007 | 02:06 PM
  #34
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
i just got of the phone with a Grand Rock dealer, and they said that internal mufflers wont make any reduction in nois levels??? and they install them for fuel savings only??? now im missing somthing or what ?
Old May 2, 2007 | 03:57 PM
  #35
outdoormaniac's Avatar
outdoormaniac
7" stacks eh, wheeew! I just cut the muffler out on my 3.5" exhaust and pullin a hill its pretty freaken loud. You guys runnin real high HP with those or what. I have a spare set of 5" x 48" turned out, and a set of 6" x 48" strait stacks off the Pete. I wanna stick dual 5" on my powerstroke but some folks say not to put too big a pipe on unless you got some major HP goin on. The truck is pretty much stock except for a 6 position bullydog chip.
Old May 2, 2007 | 04:59 PM
  #36
PETE'S_6.0PSD
check my sighature, and you will see, i didnt do a dyno yet but i should be up450-500 RWH, i hope
Old May 2, 2007 | 08:43 PM
  #37
RAMPAGE_F350
Sounds like you need to put a 4 inch MBRP muffler or similar under the truck to quiet things down. It would probably be cheaper too.
Old May 2, 2007 | 08:53 PM
  #38
PETE'S_6.0PSD
what about this? http://www.aeroexhaust.com/aero_turbine_xl_5050xl.html
i heard good things about it, and Jo "CSIPSD" is running it, so i know its expensive but i think with resonator inside might help me with drone a lot,
any of you guys running that ??
Old May 2, 2007 | 09:42 PM
  #39
jtharvey's Avatar
jtharvey
I thought about trying the Aeroturbine to reduce my drone, but haven't done it yet. I've also looked into a straight through muffler from Magnaflow, since it's not too big around.
Jason Hessell
Nov 2, 2012 09:58 PM
Mike Owens
17
Jan 26, 2011 04:03 PM
That_Just_Happened
30
Jan 8, 2009 08:40 AM
fxstbchopper
22
Nov 7, 2007 10:07 PM
bigpowerstroke
Sep 2, 2004 08:29 PM
