Starting problems
Old Apr 29, 2007 | 08:48 PM
Dewalt17fan's Avatar
Dewalt17fan
Unhappy Starting problems
My 97 has been giving me problems starting. It acts like the battery is about dead, then it fires up.
Old Apr 30, 2007 | 06:52 AM
Cuda_jim's Avatar
Cuda_jim
Clean your battery connections. The stater solenoid and starter connections too.
Have the batteries load tested. They must be check individually. If one battery is bad you need to replace both at the same time IMO. Have your charging system checked too.
Old Apr 30, 2007 | 06:59 AM
ford390gashog's Avatar
ford390gashog
your batteries could be weak or your starter brushes are shot causing a high amp draw and slow cranking.
Old Apr 30, 2007 | 07:09 AM
F350_Hauler's Avatar
F350_Hauler
Check all battery cable connections by disconnecting and cleaning and re-connecting. Load test both batteries individually while they are disconnected. If they test out good and the cleaning service doesn't solve your problem it's probably your starter. If you put the batteries overnight on a good 10 amp charger and it starts up fine in the am, then it's probably one of your batteries or maybe your charging system is not up to snuff. It's probably going to end up being your starter but you should do the above-mentioned stuff anyway because reduced power to a new starter motor will quickly turn it into a weak used starter motor.
Old Apr 30, 2007 | 04:13 PM
Dewalt17fan
Both batteries are less than a yr old.
Old Apr 30, 2007 | 05:20 PM
ForemanES's Avatar
ForemanES
Clean up those connections, mine did this same thing and the batteries were about 1 year old. There is a red spray that you can put on the terminals to help prevent this from happening again.
cbwarrior
Jul 28, 2006 11:52 AM
StrangeRanger
Nov 4, 2002 04:32 PM
71swissaqua
Sep 18, 2002 12:50 PM
pete6114
Mar 1, 2001 09:55 PM
PAUL_2
Nov 11, 2000 04:32 PM
