Gear ratio
Old Apr 29, 2007 | 06:38 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Gear ratio
Can you put 4.10 Gears in the Excursion instead of the stock 3.73?
Thanks
Nick
Old Apr 29, 2007 | 07:58 PM
i eat hybrids's Avatar
i eat hybrids
ya you can. But for the cost diff, it be worth going up to a 4.30.
Old Apr 29, 2007 | 11:24 PM
weekendwarriorfsw32
Master of Strokes
is it just switching the gears or is it the whole axel
Old Apr 30, 2007 | 11:19 AM
Antelope V-10's Avatar
Antelope V-10
Just the ring and pinion {gears}
Old Apr 30, 2007 | 07:55 PM
i eat hybrids
same axle. Were are you going to buy them at?
Old Apr 30, 2007 | 10:34 PM
weekendwarriorfsw32
Master of Strokes
Thats what i was going to ask next
Old Apr 30, 2007 | 11:50 PM
betontheturtle's Avatar
betontheturtle
should do front and rear axles if 4x4 or just up size the tires and get the same results
Old Apr 30, 2007 | 11:52 PM
weekendwarriorfsw32
Master of Strokes
I should replace the front and back
Old Apr 30, 2007 | 11:56 PM
betontheturtle
if that was a question the answer is yes imo otherwise your front and rear axles will be turning at different rates when in 4x4, not a good thing.
Old Apr 30, 2007 | 11:58 PM
weekendwarriorfsw32
Master of Strokes
would it damage it
Old May 1, 2007 | 12:12 AM
housedad's Avatar
housedad
Originally Posted by weekendwarriorfsw32
would it damage it
On pavement, 4X4 with different axle ratios it would wreck the drivetrain real soon, like in minutes, depending on vehicle speed and the amount of turns. On dirt, a couple of hours later, IMO.
Old May 1, 2007 | 12:19 AM
Monsta's Avatar
Monsta
Sit. Stay.
You can't have two different ratios.
Larger tires WILL NOT do the same thing as higher (numerically) gears.
Gears can be purchased from a variety of places. You can even start at the dealer where a new R&P will run around $200 or so. Randy's Ring and Pinion is a trusted aftermarket source but there are lots of places out there.
Lo0k to spend $2000+ to purchase and have installed your new gears. BTW, 4.30s on the PSD will be great for pulling heavy, heavy loads...in fact, loads that your truck isn't even rated for. So unless you're putting some big meats underneath, save your dough.
If you want it just to improve acceleration, there are cheaper methods for doing that on a PSD truck.
FOUNTAIN 1
Apr 3, 2017 08:41 PM
72CC428
May 13, 2016 08:32 PM
Bigdogca1966
Apr 29, 2016 09:50 AM
pcgold
Sep 20, 2001 05:49 AM
jowilker
Jun 1, 2001 09:41 AM
