TS Performance chip files
Old Apr 24, 2007 | 11:07 PM
kalsc's Avatar
kalsc
Hey all, just curious if anyone knows where a person can find a list of what the file names translate into for the related years applications.
For example, my TS chip is programmed with the XLE7xxx file series, this applies to my 99. But, since I have the programmer and a list of all the files for other years, which file series apply to the 01 computer?
I realize the code on the computer helps determine which files to use, but without the crossreference file, it's kind of difficult to know which files to use. :-)
Anybody happen to have the list or at least know where to get it?
Cheers!
Sean
Old Apr 24, 2007 | 11:19 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I bought one off of ebay that had a NVK4 code on it for my 01 with a PMT2 code on the PCM. Worked fine and I was told that was the one for an 01 auto. Hope that helps. That's all I know about it.
Old Apr 24, 2007 | 11:32 PM
kalsc's Avatar
kalsc
Nice!!! That definately helps. Thanks for that.
Old Apr 25, 2007 | 08:24 AM
DCSpecial's Avatar
DCSpecial
01 auto SDs came with PMT series codes.
00 auto SDs had the NVK series codes.
These are all what came stock mind you.
The two popular ones to run in a 00-01 is PMT1 or NVK4.
I run NVK4 files in my 2001 auto.
Old Apr 25, 2007 | 11:32 AM
CSIPSD's Avatar
CSIPSD
Towing is better with the PMT programs. NVK unlocks the TC whenever you touch the brakes.
Old Apr 26, 2007 | 08:03 PM
kalsc's Avatar
kalsc
Thanks for the info guys. Anyone know where I can get a hold of related, newer files? For example, my chip currently has XLE7.ORI (pos 1) and XLE7HILD (pos 2), what I have on the CD (for either PMT or NVK) is NVK4STOCK and nothing for the high idle program. I have positions 3 to 6 covered with the 50, 75, 100 and 140 (fuel) programs which are on the CD.
Also, the date stamps on the files on my chip are from 12/8/2007 where as the dates on the files on the CD I have are 10/31/2002.
If I am going to reprogram my chip using the burner I have, I'd sure like to use the newer files.
Next question, anyone ever pulled a program off of the chip as opposed to just erasing it?
Cheers!
Old May 1, 2007 | 10:23 PM
kalsc's Avatar
kalsc
Nobody does thier own programming by flashing chips?
Old May 1, 2007 | 10:59 PM
Tenn01PSD350
Not us, and those that do protect their proprietary info and for good reason. Where did you get this equipment and tuning data?
Old May 1, 2007 | 11:07 PM
kalsc's Avatar
kalsc
Figured as much, but as with most things, I figured there would be an 'underground' if you will. No worries, I'll get it sorted out.
Thanks.
Old May 2, 2007 | 12:14 PM
CSIPSD's Avatar
CSIPSD
You can buy burners and such from TS performance, call them and ask. They send you files that can be slected but not changed and you can burn your own chips. I have been kicking around getting one so Tadd can just E-mail my tunes to me, rather then ship a chip of to him.
Old May 24, 2007 | 08:39 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
do they have one for a 2000 excursion with AXD1 code?
Old May 25, 2007 | 07:37 AM
CSIPSD's Avatar
CSIPSD
I would assume so, but you just have to call them!
terrymargate
Feb 4, 2021 05:47 PM
dstig1
Garage & Workshop
13
Jul 25, 2018 03:14 PM
ATP Pilot
Jan 17, 2018 06:32 PM
bg56
Mar 21, 2017 05:14 PM
xjcamaro89
2004 - 2008 F150
Jul 18, 2011 05:44 PM
