Sponsored by: Real Truck
Tow Haul mode problem
Old Oct 30, 2007 | 12:03 PM
Beerstalker's Avatar
Beerstalker
That is strange, the 04 6.0L Deisel Supplement shows it on the dash cluster by the oil temp gauge (the 03 one doesn't talk about tow/haul at all). Were they all trucks, because I don't think the 03, 04 vans had it?
Old Oct 30, 2007 | 01:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
They were all F series. The most recent van is the one I still have, it's a 2002. It has OD off on the shifter.
Old Nov 1, 2007 | 07:57 PM
johnnysF350's Avatar
johnnysF350
Originally Posted by Mark Kovalsky
The '03 and '04 trucks that I used to have had the tow/haul light on the shifter. The '05 I had was in the dash. All three were 6.0L trucks.
I can speak for the '03 Super Duty personally as I had one and my T/H light was on the end of the shifter. As far as the '04 I can only assume it was the same because it had the same cluster. From '05 and up the clusters were different.
Old Nov 1, 2007 | 08:52 PM
redford's Avatar
redford
FTE Leadership Emeritus
O/D off light is a different thing from the Tow Haul mode, but it sounds like the pre 2005 trucks used the same light at the end of the shifter, but with different words on it.
Old Nov 2, 2007 | 12:34 AM
GwizRC's Avatar
GwizRC
My 03 and 05 both had the light on the dash, both said tow/haul both were 6.0lpsd.
Old Jan 28, 2014 | 02:04 AM
jkey.bama's Avatar
jkey.bama
I have an 04 F350 drw w/5spdod and the light is in the dash, not shift lever. My switch has quit working and this thread search gave me insight on how & what to fix. Thanks guys for the help! Although I stayed at a Holiday Inn Express last night, I couldn't have tackled this problem without your help!
Old Oct 27, 2024 | 06:46 AM
nicoleglowa's Avatar
nicoleglowa
1st Gear
Can you send me the schematic? Nicolethelmbt@gmail.com
Hey send me that my truck is doing this omg!!!! Thank u!!!!!!!!!!!!!!nicolethelmbt@gmail.com
Originally Posted by FortyFords
Chk fuse 24 and 34 .
then you need to chk that your brake lights are working .the brake pedal switch is in the circuit.Also the vss sensor and oss are part of that circuit also .
but you have no light on the dash so I would think that a fuse is blown or a broken wire in the steering column.
Got a fax # i'll fax the schematic to you.
Rich
99expyTN
6.4L Power Stroke Diesel
Feb 13, 2025 07:20 PM
EdInArk
Large Truck
Feb 27, 2017 08:23 PM
BigDaddy_2
6.7L Power Stroke Diesel
22
Oct 3, 2015 12:41 AM
xsportplyer
Mar 1, 2012 07:51 PM
Nathan
Dec 2, 2010 04:53 PM
