Sponsored by: Real Truck
Reverse light wire
Old Apr 24, 2007 | 06:59 AM
mastercaster's Avatar
mastercaster
Reverse light wire
any know what color the reverse light wire is to tap into? truck is an '05 psd six speed. thanks.
Old Apr 24, 2007 | 10:37 AM
wlihntr's Avatar
wlihntr
on older trucks its black/ light green ( in the trailer pug harness) i dont know if its the same on the newer trucks. you could test it and find out
Old Apr 24, 2007 | 11:35 AM
BullDog24's Avatar
BullDog24
at the tail light its black w/ purple stripe
Old Apr 24, 2007 | 11:43 AM
blackhat620's Avatar
blackhat620
mastercaster,
"wlihntr" has got you covered, it is Black with Green tracer, can be found on the frame or under the dash up around the fuse block.
Here is a recent thread were "Bear Hunter" did and install and write up of additional backup lights.
http://www.ford-trucks.com/forums/59...with-pics.html
Hope this helps
Old Apr 24, 2007 | 12:58 PM
TXHillCountry's Avatar
TXHillCountry
If you're pulling it from the harness that goes into the back of the 7-pin trailer plug (assuming you've got the 7pin plug), then it should be the center pin wire.
TX
Old Apr 24, 2007 | 03:04 PM
Beerstalker's Avatar
Beerstalker
There is a wire in the fuse panel beneath the steering column that is 12V+ when the vehicle is shifted into reverse. It is on the lower passenger side of the fuse panel, it is a black wire with pink tracer. Here is a picture of it from where I tapped into it in my truck.
My truck is an 07, I would think it would be the same on the 05-07, possibly the earlier trucks too.
Old Apr 24, 2007 | 07:28 PM
ken kenmnedy's Avatar
ken kenmnedy
Talking
yup black with a pink tracer I got it under the hood where the harness comes out use it to fier my relay.
Old Apr 24, 2007 | 07:47 PM
TXHillCountry
AAAAAAaaggghhhhh!!!!! My ears ! My eyes!!
Trath67
Mar 19, 2021 08:20 PM
SniperVision
Jul 17, 2016 09:18 AM
JRD761
Electrical Systems/Wiring
May 11, 2015 02:11 PM
GormGorm
Sep 24, 2012 11:24 PM
khadma
Dec 25, 2007 12:52 PM
