I posted this question in the electrical forum also.
07 Explorer
I need to locate the reverse light wiring. I want to install additional reverse lights and need to tap a relay in to the wire that leads to the reverse lights.
I tried checking on the12volt.com but they didn't have your truck listed. Can you pull one of the tail lights out and get the wire color off of that? Maybe call the parts dept of a dealership? Or as previously mentioned, a Haynes/Chilton's will have a wiring diagram. Those are worth having around anyways...
