Reverse Light Wire at steering wheel - 2011 F250 6.7 Diesel - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Misc. > Electrical Systems/Wiring
Reload this Page >
Old 05-11-2015, 09:48 AM
JRD761
JRD761 is offline
JRD761 is starting off with a positive reputation.
I have a 2011 F-250 6.7L Diesel.
I need to locate a 12V+ wire that controls the reverse lights under the dashboard.. I need to tap into it to get a control for a relay that's going to turn on auxiliary lights to make them turn on whenever the truck is put into reverse and the reverse lights come on. Anyone know where I can find this wire, and which wire it is?
Old 05-11-2015, 01:47 PM
projectSHO89
projectSHO89 is online now
projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.
Tap off the Blue/White wire on the connector for the Body Control Module, located behind the right side kick panel. That wire is HOT in Reverse when the ignition is on.
The other end of that wire comes through one of the firewall connectors up behind the left side of the dash, runs down the driver's side A-pillar, under the seats, than back to the passenger side A-pillar.
Old 05-11-2015, 01:53 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Is that wire for the auto dimming rear view mirror?
Old 05-11-2015, 02:11 PM
projectSHO89
No and yes.
No, because that signal feeds into the BCM where it serves as an input the network of microprocessors. That's the only physical wire that changes voltage with the selection of reverse that runs inside the cabin and is in parallel to the actual reversing lamp feed.
Yes because everything else in the vehicle relies on the digital data from the BCM over the network in regards to the status of the reversing lamps. The auto-dim mirror, the cluster display, in-dash A/V, etc all get the status from the network.
bigcountry1009
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-13-2017 10:54 AM
oceantrav
1999 to 2016 Super Duty
01-02-2017 03:44 PM
toofazt
13
11-04-2016 03:58 PM
77f2504by4
10-23-2015 09:35 PM
F250_6.7
09-02-2015 02:17 PM
Quick Reply: Reverse Light Wire at steering wheel - 2011 F250 6.7 Diesel
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
