1978 - 1996 Big Bronco
starting problems
Old Apr 18, 2007 | 01:56 PM
dino360's Avatar
dino360
Cool starting problems
My Bronco with a 5.8 starts and runs fine when cold. After running and warming up, the starter sometimes drags like if a low battery. I have already replaced the battery and the cables and I still get the same problem. It will drag a little bit and then after a few tries, it cranks up properly. Any ideas?
Old Apr 19, 2007 | 06:31 AM
chevygoneford's Avatar
chevygoneford
check your timing if its to far advanced youll have the problem your having or your starter could be going south
Old Apr 19, 2007 | 07:59 AM
Scopie's Avatar
Scopie
I had this exact same problem mate. and I have an 84 Bronco XLT with a brand new low comp engine. your symptoms are the same as I had. it felt like the battery was flat when trying to start hot... "rrrru... rrru... rrru..."
I fixed it, by doing the following;
Installing new 750 cca battery.
New cable between battery - starter relay, extra thick
New cable between starter relay & starter motor, extra thicK
New grounding cable between Battery & engine block
New Ground strap between engine & truck chassis.
this all cost me about $200 aud (battery was $150)
I work at Sydney Buses so the mechanics let me at some very thick heavy vehicle starter cable, which i crimped & welded to make the cables listed above.
I put all the parts in at once, so i dont know which bit was the cause, however i did notice once that the cable between the battery & starter relay was *very* hot.
let me know how you go. I have some spare starter cable left over if you want ot pay postage, easily enough for another truck.
-Sean
Old Apr 19, 2007 | 08:18 AM
Kemicalburns's Avatar
Kemicalburns
take the starter down and have it tested. are you running headers? heat will destroy a starter fast
Old Apr 26, 2007 | 05:14 PM
dino360's Avatar
dino360
Thanks for the info guys. I have already changed batteries and cables so I dont think that is the problem. I will check the timing to find out if that is the problem and no I am not running headers. I do have a rear seal oil leak, to yall think the oil on the starter could be causing this? thanks
Old Apr 26, 2007 | 07:28 PM
cfrives3's Avatar
cfrives3
I won't say the oil won't do it, but my 6.9 is a bit of an oil puker, and it never has seemed to effect the starter.
Old Apr 27, 2007 | 10:46 AM
Kemicalburns
i bet the starter is bad
Old May 1, 2007 | 08:29 AM
lbianc1's Avatar
lbianc1
Tyipical symptoms of a bad starter are that it starts fine cold but has trouble when warm.
It's got to be the starter.
Also, someone mentioned that their cables coming off the battery were hot; 9 times out of 10, that means that you have a bad connection somewhere.
69jwatson
17
Feb 2, 2013 02:55 PM
sand1
28
Mar 4, 2008 07:57 PM
dino360
Jan 11, 2007 04:54 PM
Badgerflat
1983 - 2012 Ranger & B-Series
Jul 30, 2005 06:30 PM
Mud_Hunter
23
Sep 7, 2004 09:54 AM
