Battery drain issue
Old Feb 1, 2013 | 05:39 PM
69jwatson's Avatar
69jwatson
Battery drain issue
After replacing battery, starter and alternator the truck really drags like the battery is dead. Was starting fine then after sitting without running for a month or so I tried starting. Thought it was just from sitting so I jumped it and it started right up. Checked the voltage after starting and it read 14.53, after I shut it off, ran for 30 min, checked the voltage and it read 12.34. I tried starting and it dragged just like it did before jumping. I took the positive side off and checked for drain but got nothing on the voltmeter. Any suggestions?
Old Feb 1, 2013 | 05:44 PM
Gembone's Avatar
Gembone
We could use a little more info about the truck and engine.
Also does it have an external voltage regulator?
Old Feb 1, 2013 | 05:52 PM
69jwatson's Avatar
69jwatson
Sorry about that, I have a 69 F100 ranger with the 360fe. It does have a voltage regulator and I already replace that. Forgot to mention that in my first thread. I was a little frustrated and posted to quick without much detail.
Old Feb 1, 2013 | 06:08 PM
69jwatson's Avatar
69jwatson
Is it possible that I didn't allow it enough time to charge the battery back up? While sitting for a month my son did leave the key on so the battery was pretty dead.
Old Feb 1, 2013 | 06:13 PM
Gembone's Avatar
Gembone
I would take and have the battery tested. if you take them too far down for extended amount of time they can have issues from that.
Many parts stores will test a battery for free.
Old Feb 1, 2013 | 07:01 PM
rustywheel68's Avatar
rustywheel68
if you had 14.53v while running, the alternator and voltage regulator are fine.
is this battery new, or is this the one that sat for a month without starting?
you say after running for 30 minutes, the voltage was 12.34.
is this with the truck running, or not running?
Old Feb 1, 2013 | 09:26 PM
69jwatson's Avatar
69jwatson
this is the same battery that sat for a month and went dead. However, it is not even a year old. The voltage was 12.3 after the truck was shut off, I tested the posts on the battery
Old Feb 1, 2013 | 09:29 PM
Redmanbob's Avatar
Redmanbob
additional info same /similar concerns..
332-428 Ford FE Engine Forum: O/T Can a voltage regulator "stick" and cause a battery to run down?
Old Feb 1, 2013 | 10:16 PM
Gembone's Avatar
Gembone
just because a voltage regulator charges a battery doesn't mean it "shuts off"(for lack of a better term) so it doesn't drain the battery.
Also how are you testing the battery? You need to test it under a load.
Check to see it it drops below 10 under a load like cranking.
Just things to check until someone with more knowledge than myself comes along.
Old Feb 1, 2013 | 10:18 PM
69jwatson's Avatar
69jwatson
Ok. Will check now and get back with you
Old Feb 1, 2013 | 10:28 PM
69jwatson's Avatar
69jwatson
Ok. So had my boy crank it over while I checked the volts. It read between 6.2-6.8 while trying to start
Old Feb 1, 2013 | 10:31 PM
Gembone's Avatar
Gembone
then the battery is bad as long as all your connections are fine.
Old Feb 1, 2013 | 10:32 PM
Gembone's Avatar
Gembone
battery under normal cranking load should not drop below 10.
Old Feb 1, 2013 | 10:34 PM
69jwatson's Avatar
69jwatson
Thanks for the help...I will get a new one tomorrow
Old Feb 2, 2013 | 05:34 AM
rustywheel68
this is true- i tend to forget that some people are still running the sticky old points-style regulators.
you've already replaced everything else...if you're getting a new battery, throw $15 at a modern regulator.
