1978 - 1996 Big Bronco
Starting problem
Old Jan 11, 2007 | 03:53 PM
dino360's Avatar
dino360
Cool Starting problem
I have a 1988 bronco with a 5.8. The engine runs strong and solid but sometimes has problems starting. It usually starts right up when the engine is cold but after using it and warming up it will sometimes drag like a dead battery. You can let it sit a few minutes or continue to try to crank it and it will suddenly crank up normally and start. The enging did have a rear seal leak before so I was thinking maybe oil build up on the starter fouling it up. I was fixing to check and clean all cables from the battery, solenoid, starter, any other suggestions before I start trouble shooting?
Old Jan 11, 2007 | 04:12 PM
wileec's Avatar
wileec
Sounds like you are on theright track my 95 did simlar things got a new battery harness now much better
Old Jan 11, 2007 | 04:54 PM
hdgapeach's Avatar
hdgapeach
Yep, clean those cable ends AND what they are connected to. Something else I did to my '77 was install new, heavier gauged battery cables. More electrical flow with less possibility for resistance with those larger ones. Solved my "hot start" problems.
51PanelMan
Feb 15, 2012 01:29 PM
thumper869
Oct 27, 2009 01:17 AM
dino360
Electrical Systems/Wiring
Jan 12, 2007 09:41 AM
jackone
16
May 14, 2006 03:25 PM
myankow
27
Aug 28, 2004 09:36 PM
