400 Charging System Not Functioning - What else could the problem be?
Old May 3, 2007 | 09:01 PM
  #91
ihateminimumwage's Avatar
ihateminimumwage
Well, just ripped out my dash (again), and followed the green/red. It is the wire that I said looked orange/green. That splits off and connects to a small red/yellow wire, which goes to the gauge cluster, and a large red/yellow that goes to the fusebox and another thick orange (red)/green wire that goes back up past the heater controls, and to I don't know where. Can't get past the heater core...
When battery is disconnected, with MM on neg bat and S terminal, it reads battery voltage, with ground strap on battery, MM in same position it reads only 5.4 mV... THis is with no ignition switch installed.
Also, off the subject, what's the large black plastic box attached to the cab behind the gauge cluster? It's about an inch deep, and 4" or 5" squared... Just wondering.
Old May 3, 2007 | 09:32 PM
  #92
danlee's Avatar
danlee
I can't help you with your wiring, because I don't have a wiring diagram that matches your truck.
I do wonder if:
You lost the ground to your voltage regulator or:
You miswired the voltage regulator when you first replaced it.
Old May 3, 2007 | 09:40 PM
  #93
ihateminimumwage
I haven't rewired anything on the VR, it's just a clip in harness. VR still registers the battery voltage when I test it's ground.
This is driving me f'n crazy!!
Old May 3, 2007 | 11:32 PM
  #94
grego's Avatar
grego
you said the ammeter was disconnected before. Maybe try disconnecting it again and see (with battery connected) if you have voltage at S, with the ignition off.
I'm grasping at straws but it's all I can think of without laying eyes on it.
Old May 4, 2007 | 12:19 AM
  #95
ihateminimumwage
Just unhooked it, no change.
So from what I can figure, my truck has turned into the damn X-Files of electrical problems...
Old May 4, 2007 | 06:20 AM
  #96
danlee's Avatar
danlee
Please explain where you measure the battery voltage and how you test the ground.
Old May 4, 2007 | 08:54 AM
  #97
ihateminimumwage
Take your voltmeter, and put the + probe on the + of the battery. Put the neg probe on the case of the regulator. You should get 12 volts. If not, the reg may have a ground problem.
This is how I tested the VR's ground.
Battery voltage, I was just putting the MM to the battery terminals.
Old May 4, 2007 | 02:30 PM
  #98
grego's Avatar
grego
Did you ever find the ballast resistor?
Was it a ceramic (rectangular) resistor type or was it a section of resistor wire?
Danlee had conjectured that if it were the second type, it could have overheated and shorted through to another wire in the harness and be feeding power back into the regulator (through the S terminal).
I have a Haynes manual for Lincolns that says something about there being a period in the seventies where this implementation was done poorly and how to reroute a new resistance wire.
Old May 4, 2007 | 03:24 PM
  #99
cj413's Avatar
cj413
Taylor,
I have the same problem and i've been following closely and trying the same things on my 75 f100. I feel your Pain!!!!
cj
Old May 4, 2007 | 03:58 PM
  #100
cj413's Avatar
cj413
What about the electric choke and the wire leading up to it from the stator or voltage regulator. I donno....i've replaced everything too and this seems the only connected piece left that may have shorted.
cj
Old May 4, 2007 | 04:52 PM
  #101
grego's Avatar
grego
cj
That wire should connect between the common winding point (STA terminal) on the alternator and the electric choke. It's ok for this to be open (disconnected, at the choke) but probably not a good thing to be shorted to ground (or anywhere else).
Assuming you have an ammeter in the dash. If you have an idiot "charge" light, then it also connects to the S terminal of the regulator.
Old May 4, 2007 | 08:44 PM
  #102
ihateminimumwage
If I had any clue what a resistor wire or a ceramic resistor looked like, I'd know if I'd seen one. I've only seen plain old wiring so far. Where is it usually located?
I have the next two days off, so I'm spending them on the truck, hopefully some of you folks (mainly the big 3 of Franklin2, Danlee & Grego) will be on here at one time or another.
I'm pulling the dash tomorrow, and I'm going to go back through each and every test, and write down all the info. I'll it all in one post, so nobody has to keep jumping back looking for info.
Old May 4, 2007 | 08:57 PM
  #103
danlee's Avatar
danlee
I found a regulator wiring diagram in an old Chiltons manual.
My first question is:
What is the voltage on the 'I' terminal of the regulator with the keyswitch 'OFF' or disconnected?
At The same time measure the voltage at the A+ terminal, the S terminal, and the F terminal.
Measure these with the (-) lead of the meter connected to the battery (-) terminal and the battery ground lead connected.
Old May 4, 2007 | 09:02 PM
  #104
ihateminimumwage
Can't measure the voltage at the I terminal, as it's under the plastic harness. I can try and run jumpers between the harness and the reg pins though...
Not sure what you mean by the A+ terminal...
Old May 4, 2007 | 09:12 PM
  #105
danlee's Avatar
danlee
According to my schematic, there is a connection from the Alternator output and a terminal marked A+. The schematic that I have is for a vehicle with an idiot light, a vehicle with an Ammeter may be different.
How many pins do you have on the regulator and how are they labeled?
