68 left blinker
Old Apr 14, 2007 | 09:38 PM
$Simpleman76's Avatar
$Simpleman76
68 left blinker
what can cause a bliker on a 68 to not blink, we have changed the flasher and replaced the bulbs, but when the left blinker is turned on the light in the dash comes on but does not blink, what else do I need to check
thanks
Old Apr 14, 2007 | 11:18 PM
Mil1ion's Avatar
Mil1ion
Flasher, a bad filament in the bulb and ground for that socket.
Ford T/S lights require both the front and rear bulb to illuminate to cause them to flash.
Old Apr 15, 2007 | 05:25 AM
jowilker's Avatar
jowilker
Dirt and corrosion are the biggest culprits. The brake and blinker as you call it share the same filament in the bulb. Test your bulb on the other side of the truck. Should it work on the right side you can eliminate the bulb as the culprit.
There are three wires that come to the rear of the truck. Dennis can help with which color goes where. One of the three wires is the tail/license plate wire, the other two are the brake (shared) and the left and right blinker.
Use a battery terminal brush in the sockets and try to clean any dirt or corrosion out.
John
Old Apr 15, 2007 | 05:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
thanks
FYI: There are two flashers under the dash. One for turn signals, one for the emergency flashers.
If the signals flash on one side, but not the other, it isn't the flasher..it's a wiring/connection issue, or a bad bulb (#1157 clear /# 1157NA amber). If the bulb lights up in the front, but doesn't flash, it could be a burned out taillight bulb...check that.
LuckyGhost
All Things Towing
Jan 22, 2017 12:05 PM
miihere24
44
Jan 14, 2016 12:32 PM
ryank59701
Nov 28, 2015 10:19 PM
aortizexcursion
Feb 20, 2014 01:04 PM
balingwire
Dec 6, 2009 07:57 PM
