No blinkers No hazards
91 F150 Lariat: Had no brakes or turn signals, only flashers. I replaced the turn signal switch inside the steering column & the relay in the fuse box. Checked & replaced any related fuses (She is a new to me old truck)
Brake lights-CHECK!!
Blinkers blinked one time left, & then nothing. I have no blinkers & no inside lighted arrows. My hazards do not work now either. The new switch is not defective bc it does click left & right as if the turn signals were actually on. What to check next??? Anyone?
Last edited by LuckyGhost; 07-30-2016 at 07:10 AM. Reason: Forgot to add truck year
HELP!!!! lights work all the way around whn on no brake light hazard or turning signal only on back
99 ford f350 7.3 all lights turn on but brake light hazard or turning signal on driver side tail wont do anything front works back wont. Ive tried swaping bulbs. The multifunction switch looked at wires dnt see anything wrong HELP!!!!!!!
99 ford f350 7.3 all lights turn on but brake light hazard or turning signal on driver side tail wont do anything front works back wont. Ive tried swaping bulbs. The multifunction switch looked at wires dnt see anything wrong check fuses as well HELP!!!!!!!
feeble
16
07-11-2015 04:22 PM
optiboli
04-12-2006 02:51 PM
