1966 - 1977 Early Broncos
Distributor identification
Old Apr 23, 2007 | 11:05 AM
RCrawler's Avatar
RCrawler
Originally Posted by v8xploder
Im confused now if im not mistaken arent they case grounded?
Yes, if the starter is loose or otherwise not making a good connection, or the ground at the engine is bad, the starter won't work.
Sorry for the confusion.
Jason
Old Apr 29, 2007 | 07:15 PM
v8xploder's Avatar
v8xploder
Finally got some time to pull the starter off, and as I did a metal ring fell out with it.it looks somewhat like a beefy snap ring without the gripping holes. Looking deeper the ring seems to look like she broke off the end of the slider shaft. I used jumper cables to see if the starter worked and it was very weak. What could have caused this, or could this be a common prob? It just seems like an odd area to break.
Old May 1, 2007 | 09:58 PM
v8xploder's Avatar
v8xploder
Ok, So I get a new starter, Put it in everything goes smooth. UNTIlL I try to turn it over. CLUNK. same thing. Engine locks up against the starter, . I pulled the starter off and engine turns freely. Looking at the new starter it looks like the flywheel is catching against the "mouth" of where the starter drive gear, it has some scuffs on it. Do I have the wrong starter, they were identical... The one that I took out of it was in there since I bought it in oct 06 and I drove it all the time with no problems, so I know that has to be the right one....
Old May 2, 2007 | 12:37 AM
RCrawler's Avatar
RCrawler
I can't remember, did you swap transmissions? Automatic and manual starters are different and won't interchange. There is a difference in the length of the nose that goes into the bellhousing. I don't have the measurements right now, but I could find them this weekend.
Jason
Old May 6, 2007 | 05:22 PM
v8xploder's Avatar
v8xploder
I got the right starter, there is a difference in the car and truck 351 starters, about an 1/16 of an inch of metal in the opening where the drive gear is. My 351 came out of a car it seems.
Old May 7, 2007 | 12:59 AM
RCrawler's Avatar
RCrawler
I think the Econoline was the only vehicle in the Ford line to get the Windsor in 79. The cars and the pickups used the 351M, which may be the difference in starters.
Doesn't matter as long as you got it running again.
Jason
Old May 7, 2007 | 01:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Jason
First 351W in Econoline: 1975. First 351M/400 in Econoline: 1980
First 351M/400 in F Series: 1977 (Bronco: 1978) / First 351W in F Series & Bronco: 1980
Last year for 351M/400: 1982
Cars used 351C: 1970/74 / 351M: 1975/79 (exc 1979 Big Ford) / 351W: 1969/79 (and later on Crown Vics)
D7AZ-12250-A .. Resistor Wire ~ Coil to Ignition Switch 49"-length color coded red with green stripes (Motorcraft DY-263)
captanron
Jun 15, 2016 06:14 PM
Gertie-The '49 F2
Oct 25, 2015 10:29 PM
tardster
57
Jun 30, 2010 12:16 PM
Anafiel
Feb 15, 2010 06:27 PM
Squeak51
May 17, 2006 06:32 PM
