wobbly ride
Old Apr 14, 2007 | 04:52 PM
suicide29's Avatar
suicide29
Smile wobbly ride
would like to get a set of landyot radius rods but am having trouble finding out how. any help would be appreciated
Old Apr 14, 2007 | 10:34 PM
1 Excursion camper's Avatar
1 Excursion camper
He has a waiting list for them! I was going to order some, but I first installed a Hellwig rear sway bar. nite and day difference!!! before the sway bar the X was all over the road, it took all I had just to keep it between the lines and towing was dangerous at best. now it tracks straight and I can drive with one hand and there is no more wander. and towing is just as good as when it`s empty. you may also want to adjust the steering gear box to take some slack out of it, probably about 3/4 of a turn.
X HEMI Guy may also chime in. he may have some more info than I do.
Old Apr 14, 2007 | 11:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
You can email him by using this link.
http://www.supermotors.net/users/LANDYOT
Old Apr 15, 2007 | 09:44 AM
suicide29's Avatar
suicide29
thanks, I wanna get myself on the waiting list for these things, I drove from so.maryland to cleveland and back and it was white knuckle all the way. I do a lot of road miles so I've gotta address these problems asap!
Old Apr 15, 2007 | 10:53 AM
suicide29's Avatar
suicide29
I'm not very computer savvy, I tried that link, said i needed to register, tried that it didnt work. tried through this site and it said I was too new of a user!!! getting a bit flustered
Old Apr 15, 2007 | 02:11 PM
Monsta's Avatar
Monsta
Sit. Stay.
Try the forums link. There is a thread about the RRs. http://www.supermotors.net/clubs/for...rums/index.php
Old Apr 15, 2007 | 03:18 PM
housedad's Avatar
housedad
He may have a couple in stock, but he is taking a break from making more until late, late 2007.
Old Apr 17, 2007 | 04:24 PM
suicide29's Avatar
suicide29
Ok, getting the hellwig for the rear of the X anyone tried the one for the front? should I just wait until I can finally get in touch with Landyot. Truck has 83000 on it and I'm pretty sure the shocks have never been replaced.........any recommendations there?
Old Apr 17, 2007 | 04:38 PM
sewerat's Avatar
sewerat
I have a set of radius rod sitting on my desk that have not been installed as of yet. If i get my lift kit in the next month or so i will not be putting them on so they will be up for sale. Keep in touch and i will let you know for sure what's up with them.
Old Apr 17, 2007 | 06:59 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Try these first???
83K, stock shocks, no rear sway bar???...
Since you cannot get a set of landyots...I'd start with the Hellwig as 1 Ex camper suggests...
My Ex did NOT come with a rear sway bar...but it does have a front factory one. Some Ex's come with a factory rear and some don't...
The Hellwig can be ordered from JCWhitney...they have free shipping on orders over $75 OR you can use a $15 off coupon for orders over $100...I don't have the coupon code here with me but I can send it to you if you like...
The Hellwig makes a huge improvement in handling...but BEFORE you order the Hellwig...look under your Ex to make sure there isn't one back there.
Front and rear shocks that are worn will also contribute to handling issues...I'd swap those out too...not hard at all. Bilstiens seem to be the "choice"...I haven't done anything on mine yet as I have only 27K miles.
The steering box adjustment is a HUGE improvement if you have "play"...can you rock your wheel back and forth and NOT actually engage your wheels to turn?...if so, a steering box tighten is needed...these boxes are kinda junk...
Here is the link to a post about HOW to adjust the box... https://www.ford-trucks.com/forums/6...heel-slop.html My post in that thread has some "hints"...click on the directions in my post FIRST then read my "hints"...
Also what air pressure do you run in your tires?...the Ex's can be tempormental about that too...
For such a big beast of a truck...she sure likes it HER way...hey wait a minute...don't they all! LOL
Also how are the tires wearing on the Ex?...when were they replaced?...does the steering wheel sit centered?...basically how is the alignment on your Ex?
After a BUNCH of mods on my Ex...I started noticing a "slight" wander...nothign too drastic but noticable...I took it in for an alignment and the camber is within specs BUT on the very low edge...perhaps Fords shims from the factory are all low?...I am having my shop get me a set of concentric bushings that go on the top of the ball joints...oops ball joints...keep that thought...anyway the concentric bushings are ADJUSTABLE so he can set my camber "slightly" positive versus the "slightly" negative that is there from the factory...a positive camber contributes to BETTER straight tracking...the trade off is if you go TOO high...you can get faster outside tire edge wear...I'll let everyone know how this small mod does.
NOW ball joints...these ball joints are also junk...they go between 30-50K miles...and also contribute to poor handling...mine are still solid...yours with 83K may not be. I'm told that the factory ones do NOT have a grease fitting...the aftermarket ones (MOOG?) do...so you may want to see how your ball joints and tie rods are...basically a good front end eval...that's what my alignment shop did...plus my tow is out...hence my steering wheel is slightly off center...will be fixed when he does the full alignment...
Hope this info helps...I personally wouldn't jump to the landyots first...I'd try some of the other things...then if handling is still "questionable"...look for the radius rods...but these are just my opinions...take them for what you paid!
hope this helps,
joe.
Old Apr 18, 2007 | 03:29 PM
suicide29's Avatar
suicide29
thanx sewerat I definately will stay in touch
Old Apr 18, 2007 | 03:35 PM
suicide29's Avatar
suicide29
I check the tire pressure regurlarly so that seems ok. and I most certainly did check for a rear sway bar. I didn't want to make that mistake!!!!! Getting new shocks as well just don't know which brand are the best yet, still looking for suggestions. I also planned on having the alignment done at that time so I will deffinately have them check the ball joints thanks for the heads-up
Old Apr 18, 2007 | 03:51 PM
suicide29's Avatar
suicide29
while I'm at it , what do you guys suggest for a steering stabilizer upgrade ? single, double, what brand?? thanx
powerstroke 96`
17
Nov 17, 2012 12:12 AM
NastyNateDog
Modular V10 (6.8l)
Aug 17, 2012 12:34 PM
bjoern
Dec 16, 2002 05:29 PM
TheWiz427
Sep 6, 2002 03:04 PM
stumpy2
Apr 14, 2001 10:19 PM
