1978 - 1996 Big Bronco
Hissing break peddle
Old Nov 25, 2001 | 09:17 PM
C Davis's Avatar
C Davis
[updated:LAST EDITED ON 25-Nov-01 AT 10:20 PM (EST)]Hello everybody, this is my first post. I have just rebuilt the 302 in my 83 full size Bronco XLT. Everything is just about perfect except for one thing. Whenever the break peddle is not applied there is a hissing sound, and whenever the breaks are applied, the sound goes away. I thought it could be the break power booster, but it seems to me it is more likely a vacume leak somewhere, and the power booster could be taking up the access vacume when stepping on the break peddle. I have checked everywhere I can think of with a water hose to my ear, and even though I did find a couple vacume leaks, the hissing is still there. Could someone please clue me in on this nagging problem?
Thanks,
C.Davis
Old Nov 25, 2001 | 09:45 PM
Mil1ion's Avatar
Mil1ion
Hissing BRAKE PEDAL huh?
Things to check with someone to help:
While someone steps on the BRAKE PEDAL & you have your head under the hood,give a listen around the Check Valve on the Brake booster,the vacuum tree on the manifold where all the hoses are connected, transmission vacuum line.
If you can't hear anything hissing.
Then,after getting the vacuum built up ,shut the truck off,then have that person again slowly press the BRAKE PEDAL in and you might be able to hear a difference and locate the leak.
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Nov 26, 2001 | 02:01 AM
C Davis's Avatar
C Davis
Dennis,
After I began spelling "Brake Pedal" correctly, it quit hissing at me. Just kidding, I'll try your suggestions in the morning.
Thanks,
C. Davis
Old Nov 26, 2001 | 12:59 PM
adelyser's Avatar
adelyser
To check for a vacumm leak, spray some carb cleaner at the vacumm connections, and if there is a leak, the engine speed will drop when you spray the cleaner.
Old Nov 26, 2001 | 11:05 PM
JBronco's Avatar
JBronco
Someone suggested this to me to help me find a minor vaccum leak on my a/c vent controls. I haven't tried it yet, but you should check the vacuum canister for leaks. It's the thing that looks like a coffee can painted black. The person who told me this had a leak on the seam of the canister. They fixed it with JB weld and the problem was solved. He said that he pushed on it while the engine was running, and it caused it to make the noise which helped him determine the problem. I haven't bothered trying this yet because my problem is very minor, but one day when I'm bored I will go out and look at it. But you may as well check your canister and the hoses leading to it.
Old Dec 9, 2001 | 07:30 PM
8996EBBroncos's Avatar
8996EBBroncos
Most likely, you're gonna have to get a new brake booster.
Old Dec 13, 2001 | 03:34 PM
flatspin's Avatar
flatspin
Same thing on my truck. Figured the booster was shot so I replaced it. Just the same.
I am on my way out to look at the vacuum reservoir now. Sounds logical.
Old Dec 16, 2001 | 07:05 AM
RRL78's Avatar
RRL78
I have a 1987 mercury grand marquis with a 302 and, on the top of the brake peddle there is this white little "thinga ma bob" that has two vacuum hoses too it. Well, that thing started hissing and when i apply my brakes it quits. I took one of the hoses off and stuck it too the end of a bolt, no more hissing, and brakes work fine. Im sure its replacable just hav'nt done it yet. Check see if you have one. Good luck. Rob
Old Dec 16, 2001 | 05:38 PM
Mil1ion's Avatar
Mil1ion
That's the *Check Valve* I mentioned in an earlier post.
Dennis
It's Almost Time Everyone.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=314&.jpg
Old Dec 17, 2001 | 05:51 PM
RRL78's Avatar
RRL78
The check valve you mentioned is on the brake booster, the one i'm reffering too is on the top of the brake peddle, inside the truck. If the bronco's even came equiped with one. Rob
Old Dec 17, 2001 | 05:56 PM
Mil1ion's Avatar
Mil1ion
Isn't that the Cruise control shut-off valve?
Dennis
Old Dec 22, 2001 | 07:09 PM
RRL78's Avatar
RRL78
I'm not really sure, mine was hissing and every time i hit the brakes it would quit. I took one hose off and stuck it too a bolt and, i don't hear any more hissing. All i know is my cruise control works great, and my brakes work great. Anyway, i hope this fella gets the problem fixed. Have a Merry Christmas. Rob
Old Dec 23, 2001 | 11:55 PM
gruhn367's Avatar
gruhn367
Post Hissing break peddle
Curt Bates
Jan 12, 2012 03:23 PM
CavsFan
Escape & Escape Hybrid
May 22, 2010 08:45 AM
blzfan1963
1997 - 2003 F150
May 29, 2007 12:48 PM
Ervin
Mar 11, 2007 01:11 AM
Sycostang67
May 2, 2005 03:53 AM
