Brake booster hissing
Old Mar 5, 2007 | 04:06 PM
Ervin's Avatar
Ervin
Ok I have 78 F250 4x4. Today I kept hearing a hiss in the cab. It is only when I put my foot down on the brake peddle. Does this mean a new booster or is it repairable or cheaper to rebuild The master was just a little low in the front. Or is it time to upgrade to the F350 master and booster? Thanks, Erv
Old Mar 5, 2007 | 04:24 PM
pcheyne's Avatar
pcheyne
I would replace it.
Old Mar 5, 2007 | 04:36 PM
Mil1ion's Avatar
Mil1ion
Pressing the pedal..... With the engine is running or not ?
PEDAL
Peddle is to sell something.
Can you read this?
Old Mar 5, 2007 | 04:49 PM
Ervin's Avatar
Ervin
Sorry it was a long day. When I push down the pedal slow and the engine running. Seems to stop ok. But it makes the hiss sitting and holding the pedal. No Dennis, when I make it bigger it gets blurry. Can you give the a link to it? Also I have a vacuum gauge in the truck , I see it drop, but it holds pretty steady. Erv
Old Mar 5, 2007 | 09:16 PM
firstonraceday's Avatar
firstonraceday
Same thing happened to my 77. The booster is shot and could be allowing brake fluid to leak back into it. I just got a reman booster. So far so good.
Old Mar 10, 2007 | 04:15 PM
cletus t's Avatar
cletus t
sounds like the bladder bag in the booster has a small hole. better go ahead and change it. if it blows out completey you will still have brakes but not power brakes
Old Mar 10, 2007 | 04:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
When replacing the booster or MC replace both.
Old Mar 10, 2007 | 07:28 PM
hotroddually's Avatar
hotroddually
sounds like you need a vacuum booster.
Old Mar 10, 2007 | 07:31 PM
Mil1ion's Avatar
Mil1ion
Booster diaphrams are known to go bad after 20 years. Thats why one should have a used booster from a wrecking yard inspected before it is installed.
Do the tests I posted above and know for sure.
Old Mar 10, 2007 | 07:37 PM
Ervin's Avatar
Ervin
Thanks for the help guys. I am going to go get a new booster and master tomorrow. Dennis can you give me the part numbers for the up grade to the F350 booster? I would like to price it.Thanks, Erv
Old Mar 10, 2007 | 07:52 PM
Mil1ion's Avatar
Mil1ion
w/o speed control - FT-39 or 2512300 ...(12300) booster
Old Mar 10, 2007 | 08:13 PM
Ervin's Avatar
Ervin
Thanks Dennis Erv
Old Mar 10, 2007 | 10:08 PM
fasthauler's Avatar
fasthauler
Definitely get that booster out of there. I let mine go too long and the #4 & #7 intake valves warped. The guy at the machine shop spotted it immediately. He said it is a common problem for the 460. The cold air going through the leaking booster goes straight into the #4 & #7 intakes. When the engine gets hot the cold air hitting those hot valves can warp them.
Old Mar 10, 2007 | 11:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
The lean mix can also burn valves and hole pistons.
There is an internal seal that also goes bad frequently.
Old Mar 11, 2007 | 01:11 AM
76 crew's Avatar
76 crew
with the engine off pump the brake pedal several times (maybe 5) to get all the residual vaccum (air) out of the system.
then hold the brake pedal down and start the engine the pedal should go down about an inch or so, if it does this its not your booster its something else.
when you step on the pedal with no vacuum assist (engine not running), its like manual brakes, as soon as you start the engine, the vacuum from the engine will pull on the diaphragm, and thus "helping" you push the pedal down, thats why it should drop a little more when u start the engine.
the other lazy man way is to clamp the hose coming from your engine and going to your booster. Does it get harder to push the pedal? then your setup is working, if you clamp it and brakes feel the same, then u been driving around with manual brakes and didn't even know it.
custom1106
Nov 21, 2010 08:26 AM
Sycostang67
Feb 9, 2006 10:41 AM
73f350sc
Sep 24, 2004 02:33 AM
MrPleasant
Feb 4, 2002 10:57 PM
