1978 - 1996 Big Bronco
No Brakes!
Old Dec 21, 2001 | 12:08 PM
cangiman's Avatar
cangiman
No Brakes!
Yesterday morning I heard my brakes grinding. I tried to check through the rim and there was no pad left that I could see so I planned to do the front brakes this weekend. Last night about 1 AM (thank God no traffic) I get to the stop sign step on the brakes and roll right through the intersection. Scary.
The pedal went all the way down. I drove the rest of the way home very slowly. The pedal would come back to normal for a few blocks then I'd lose the brakes again. This morning I noticed brake fluid on the front passenger rim and tire. How much damage did I do? What would cause the fluid to leak out onto the rim?
Old Dec 21, 2001 | 09:00 PM
Franklin2's Avatar
Franklin2
No Brakes!
Are you going to tackle this yourself or take it to a shop? You will probably need new rotors, calipers and pads. People complain, but I like that my state has inspections.
Old Dec 21, 2001 | 09:56 PM
Mil1ion's Avatar
Mil1ion
No Brakes!
Just remember when you do Brakes you both Front or both back ,you can't just do one side.
This job isn't really that tough of a thing to do at home.
I would guess that the rotor is pretty gouged out (possibly, Can't be turned down within minimum limit)therefore,you might need a new rotor.
If they are within tolerance an auto shop can turn them down(usually about $10 each).
Pads are sold in sets (around $23.00) make sure you get the *Correct compound make-up for your application. I suggest Semi-Metallic pads.
Now is the time to go over the calipers,from the sounds of it, you have one leaking.
Calipers are Inexpensive, go for a pair of rebuilt ones over rebuilding them yourself.
Brake fluid will be Dot 3 or Dot 4.
If you require instruction on what to do if you decide to do the work yourself,E-mail me and I'll send them to you,or purchase a shop manual and use that.
Hope this helps >
Have a great Christmas !!
Dennis
It's Almost Time Everyone.
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=314&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Dec 26, 2001 | 08:56 AM
cangiman's Avatar
cangiman
No Brakes!
Brakes are as good as new. I replaced front calipers ($15 each after returning the core) $30 bucks for pads $92 (that hurt)for a rotor and $10 to have 1 cut. $2 for brake fluid and and what seemed like forever to bleed the lines. Thanks for all the input. It was straight forward and easy enoughto do. Thanks again
Old Dec 26, 2001 | 04:40 PM
lastchance's Avatar
lastchance
No Brakes!
Encho
Dec 2, 2013 07:14 AM
whack&stack
2004 - 2008 F150
Mar 19, 2011 12:04 AM
vlietracer64
Sep 18, 2008 06:27 PM
mullinsmn
Sep 1, 2006 12:39 AM
aph453
Jan 29, 2005 11:04 AM
