Help With Brakes
Old Mar 18, 2011 | 09:22 PM
whack&stack's Avatar
whack&stack
Help With Brakes
I have been helping a buddy with his 2007 F150 we put a 6" lift on it and extended front brake lines and now we can't get the brakes to bleed. I have bled a lot of brake lines and i cant figure these out. we have bled almost 4 quarts of brake fluid through them and they still wont hold pressure. we have started at the passenger rear and then driver rear and then passenger front and then driver front just like it says to do. there are no leaks anywhere in the system. after you bleed the brakes if you wait a few seconds you can push the pedal all the way to floor. anyone had this problem before and if so how did you fix it?
Old Mar 18, 2011 | 10:17 PM
Fox Fader's Avatar
Fox Fader
Curious about this. Are you pulling the fluid through with a vac?
Old Mar 19, 2011 | 12:04 AM
whack&stack
nope using the buddy system one working the bleeder one pumping brakes
Skyforum
16
Jun 14, 2018 09:19 PM
EliteScapes
32
Apr 18, 2011 10:59 PM
szilagyic
20
Jun 10, 2010 08:24 AM
XzXPatrickXzX
Sep 30, 2009 08:35 PM
bheneee
1997 - 2003 F150
Aug 13, 2009 05:24 PM
