A/C recirc button on 06 Lariat
Old Apr 11, 2007 | 04:41 PM
osteodoc08's Avatar
osteodoc08
I've got a question for you guys. When I start up my truck, the A/C is already on and it shows it is on recirculation mode from last time before I shut my truck off, however, it isn't actually recirculating. I have to "turn it off" to turn it on again (the recirc mode). I've noticed this and it does it every time if I shut the truck off and I start it later (with the recirc "on" but not actually)
Does everyone elses do this? It's more of a PITA than anything having to turn it (recirc mode)off and then on again for it to recirculate when it should be on recirc to begin with since that is what the screen shows to begin with.
Old Apr 11, 2007 | 06:20 PM
HomerWinzlow's Avatar
HomerWinzlow
Unfortunately that is the way it works. I had to find that out the hard way on one I replaced the control head on when it did the same. I put the new control head and it did the same thing. So I checked brand new ones on the lot and they too did the same.
Old Apr 11, 2007 | 07:29 PM
mattd17's Avatar
mattd17
Air conditioning???? just use the 4-60 system...... 4 windows down, 60 mph !!!!
Old Apr 11, 2007 | 08:59 PM
osteodoc08's Avatar
osteodoc08
While a good idea, I don't think it would have been a good idea with the rain we've had lately
Well, now I know I'm not crazy. Just one of those "little characteristics" I guess.
Old Apr 11, 2007 | 09:06 PM
HomerWinzlow
I think they changed the EATC control head for 07 but Im not sure, they make so damned many changes over the years it makes your head spin to try to keep up with them.
Old Apr 11, 2007 | 09:30 PM
screwy's Avatar
screwy
Well I went out and looked at my truck. When in heat mode it switches out of recirculation the next time it’s started (no light). When in AC though it stays in recirculation (light) and it’s obviously still engaged.
Old Apr 11, 2007 | 09:36 PM
HomerWinzlow
Watch the actuator on the recirc door. When you shut down on the 06 it resets itself to fresh. When you restart it still has the light lit up but the recirc door stays on fresh. Hopefully that is not the case on your 07. If Im not mistaken the control head itself is different on the button layout even.
Old Apr 11, 2007 | 09:53 PM
screwy's Avatar
screwy
Yep, It stays on recirc, going off the air flow not the light.
Old Apr 12, 2007 | 01:29 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
mine is the same way...it also randomly puts itself into the AC mode. not all the time, just every now and again, I'll look down and see the AC lit up.
little quirks...all we can do is inform them of the issues, and the guys after us will reap the benefits.
Old Apr 12, 2007 | 09:55 AM
KevinM's Avatar
KevinM
My 04 always requires me to turn on recirculate. Even if I turn the truck off with the AC on and in recirculate, once I start it up again the recirculate is off with the AC on. This is when in auto mode. Don't know about manual mode.
Old Apr 12, 2007 | 11:03 AM
FTE Trigger's Avatar
FTE Trigger
I'm in the same boat with Kevin... I also have to manually engage the recirc. feature (man. controls '05 XL).
Old Apr 12, 2007 | 07:17 PM
nascar6dude's Avatar
nascar6dude
Guess everybody has their own way of dealing with this. Myself, I always shut down my air or heat before I turn off the ignition. Next startup, I run the truck for a minute or two before turning on either one, it always goes into the recirculating mode.
Old Apr 13, 2007 | 09:50 PM
powderburn2's Avatar
powderburn2
The buttons are to close to the cup holders on mine. When I put a big bladder busting pop in the holder it bounces into the buttons and turns the AC on or it turns the recirculate on sometimes when my wife uses the one on her side. Very poor design in my feeble opinion.
Old Apr 13, 2007 | 11:28 PM
aquaman's Avatar
aquaman
The older 4-55 model got better gas mileage
kjstanger
6.4L Power Stroke Diesel
Dec 31, 2017 09:30 PM
strokin83
May 27, 2012 10:58 PM
bmenzel
Sep 21, 2007 03:34 PM
Champ198
2004 - 2008 F150
Jun 28, 2007 09:11 PM
BLUE SUPER DUTY
May 24, 2007 12:01 PM
