6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
A/C Recirculation Mode
Old Jul 26, 2011 | 12:14 PM
kjstanger's Avatar
kjstanger
When I push the recirc. button I don't notice any change at all i.e. speed of fan, air being moved faster or any noise that would indicate that it was working. The light comes on but that's about it. Is it time to take it to the dealer?
Old Jul 26, 2011 | 12:56 PM
senix's Avatar
senix
mine has always behaved just like this as well. I though it was normal for this truck.
Old Jul 26, 2011 | 01:50 PM
kjstanger's Avatar
kjstanger
I didn't think anything of it until one day it just didn't make sense that I didn't hear the blower increase in speed. All my other trucks I would hear the blower increase and the amount of air coming out was almost double the volume. Senix, do any of your other vehicles give you some indication that the recirc has been activated? other than a light.
Old Jul 26, 2011 | 02:15 PM
senix's Avatar
senix
Yes, they increase the speed and force of the air on recirc mode.
This truck is the only one I have ever had that didn't increase.
Old Jul 26, 2011 | 02:30 PM
kjstanger's Avatar
kjstanger
Very odd.....I am calling my Ford dealer to ask about it. I'll let you know the outcome.
Old Jul 26, 2011 | 02:39 PM
kjstanger's Avatar
kjstanger
Ok, I just talked to the Ford service department and he seems to think that's not normal. I scheduled an appointment for this Thursday. We keep you up to date.
Old Jul 26, 2011 | 10:59 PM
kane gray's Avatar
kane gray
Are you pushing the recirculation button with it on auto mode? Try this if you have DATC system. Take it off auto by pushing the front vent button, then engage the recirculation mode with the fan speed on high. You should hear it come on under the passenger side. On my truck, if it is on auto mode, the button doesn't do anything. If you set it to manual mode and push it, then it comes on.
Old Jul 27, 2011 | 05:18 AM
senix's Avatar
senix
I will have to try it that way. Maybe that is the issue with the auto climate.
Old Jul 27, 2011 | 08:09 AM
kjstanger's Avatar
kjstanger
Holy Cow Kane, I don't care what Senix says about you....your ok in my book. That worked, I guess I should have payed more attention when I was quickly fanning through the owners manual and when I say fanning I mean while I was using it to shew a fly out the window. All kidding aside, thank you very much I can now cancel my appointment tomorrow.
Old Jul 27, 2011 | 08:25 AM
senix's Avatar
senix
Kane gets some reps for the fix
Old Jul 27, 2011 | 09:13 AM
tgreening's Avatar
tgreening
Not trying to take anything away from anyone but are you sure you got a "fix"? It seems to me if you push the vent button you would be getting exactly that, vented air and not a/c.
It has always been my experience with a/c that in normal mode you get fresh outside air run through the a/c system. When the a/c is on and you press the recirculation button the a/c uses the same cabin air run throught the system over and over again.
That's my story......
Old Jul 27, 2011 | 11:53 AM
kjstanger's Avatar
kjstanger
tgreening, It's not as much as a "fix" as it is just realizing how to operate the recirculation feature of the truck, in my case. Hopefully any whoa's that senix is having, which kind of sound similar to mine, this will be the answer he is looking for.
You are correct, if you push the vent button, the Auto Climate Control (ACC) turns off and you are now in "manual" control and you are getting air from outside straight to the cab. Having said that, if you push the A/C button you now have the incoming air being cooled by the conditioner and becasue the ACC is turned off you have the ability to use the recirculation feature which indeed shuts off the outside air and just used the cab air.
Old Jul 27, 2011 | 11:59 AM
LaxPlaya21's Avatar
LaxPlaya21
I always have a hard time with the DATC! Sometimes I have both the passenger and driver set at the same temp with AC on and one is blowing hot air the other is ice cold... then I notice the auto button is lit. I tend to just use manual and use the recirculate button when it is really hot out. If I don't use it, it doesn't get nearly as cold.
Old Dec 30, 2017 | 08:39 PM
dburchfield2000's Avatar
dburchfield2000
It does speed up and cool quicker when I turn it on. It just doesn't stay on all the time anymore like it used to. I saw in another post somewhere where Ford makes it turn off below 50 degree's but I'm not sure that is the case.
Old Dec 31, 2017 | 09:30 PM
Picton's Avatar
Picton
Yall have it good here near the end. It's just a bit of a bizarre way for the system to work. Essentially you have to manually disengage re-circulation mode as it is always on by default(Auto) until you hit the air direction button...if that made any sense....Happy New Year
Meatus
May 6, 2019 02:49 PM
AJ Botha
Nov 15, 2018 11:33 PM
Big-Red-Lariat
2015 - 2020 F150
Apr 16, 2016 10:14 PM
monsum
Oct 2, 2012 09:11 AM
cardinal thunder
Aug 6, 2010 02:32 PM
