"Check Charging System"
Old Apr 10, 2007 | 07:54 PM
duck fan's Avatar
duck fan
Because racetruck
My girlfriend has an '03 Expedition with ~70,000 miles. About 10 months ago the Message center reads "Check Charging System". Girlfriend took it in to some local shop and had the alternator replaced. The message center still reads "Check Charging System" Only its still the same battery from 10 months ago and we have driven the thing everywhere with no problems. Does ANYONE have any suggestions to shut the thing up???
Please help
Old Apr 10, 2007 | 09:41 PM
Franklin2's Avatar
Franklin2
Go out and check the battery voltage with a meter with the truck idling. It should be around 14 volts.
Does it crank strong or does it struggle? If it struggles sometimes, then the voltage could be dipping low enough to set the error message. If this is the case, you may need a new battery or just clean the battery cables.
Old Apr 11, 2007 | 12:47 PM
duck fan's Avatar
duck fan
Because racetruck
Thanks for the reply. I will try the voltmeter this weekend. However, It does crank nice and strong every time.
Old Apr 11, 2007 | 01:47 PM
MisterCMK's Avatar
MisterCMK
Is there a way to reset the message center? Try disconnecting the batter for 15 or 20 minutes.
Old Apr 11, 2007 | 08:15 PM
F250FarmBoy's Avatar
F250FarmBoy
Agreed with unplugging the battery. The down side is now you have to reset your radio settings...lol
Old Apr 12, 2007 | 10:44 AM
projectSHO89's Avatar
projectSHO89
Did you press the RESET button on the message center after the alternator was replaced?
This is a required step per the service manual to clear the error message.
You can also run the cluster self-test to see what value the PCM is reporting to the cluster for the measured battery voltage. Press and hold the RESET and SETUP buttons while turning the ignition to ON until the display reads TEST. Use the RESET button to advance through each step of the self-test. Look for a display of bAt###.## where ###.## represents the measurement of the battery reading in 1/10ths of a volt.
Steve
Old Apr 12, 2007 | 12:08 PM
duck fan's Avatar
duck fan
Because racetruck
I will try checking the value and resetting the message center. Thanks for all of your input.
Goat Rancher
Crossovers
Mar 26, 2017 02:48 PM
STB power systems
New Member Introductions
Sep 7, 2016 01:52 PM
AzPete
2009 - 2014 F150
Apr 8, 2016 08:36 PM
khpony
2004 - 2008 F150
Aug 17, 2015 03:49 PM
Paul37
Aug 2, 2011 11:06 AM
