boost=14psi EGT=185'f
Installed my boost,and pyro guages this weekend.No wonder my truck has no power.My boost is reading 14psi max normally.Once I hit 16psi on a cold night(35')My pyro was only reading 100'.I really thought this was wrong,but went to the place I purchased the guages and he shot my manifold w/a laser thermometer and it was 185'f on drivers side and 155'f on passenger side.What the heck is going on?
Check this out...are you SURE that THIS: https://www.ford-trucks.com/forums/5...all-point.html
isn't your problem?
Just covering bases here....
isn't your problem?
and where did the guy measure the temp?
i think as zx250 said that you have install problem, check you wires going to the Pyro gauge, make sure you have good ground, that my be the problem,
what gauges do you have ?
i had problem with my Autometer Pyro , at idle would show 750* and wot would go out of scale,
make sure your probe end its in the middle of the pipe
double check the install on the gauges, and turbo gauge did you use a ferule on the line to crimp it? maybe you crimped the line and crushed ferule,
check it again, and if you know you did it right , maybe you have bad gauge
isn't your problem?
isn't your problem?
Your gauge is not reading your EGT's. As for the lazer reading... mmm... I wouldn't think that is much above minimal flash point for fuel so I gotta question that also. The boost numbers are a little low but acceptable for a stock setup. You need to find out why your Pyro's not working and go from there. My gauge seldom falls below 300*. I'm thinking something is not grounded. If you wonder about the lazer reading, run you truck, wait a few seconds, splash a little water on the uppipe and if it turns to steam, then you know that it is above 185*
Originally Posted by OBX 7.3
My gauges are Autometer and these are the directions I followed http://www.dieselmanor.com/diy/PSD3...D73gauge-p1.htm The only step not shown, is grounding the pyrometer.I grounded mine to the lower dash chassis behind the fuse acces panel on the right hand side.There you'll find a ground bolt w/2 existing ground wires.I thought this to be suitable.I did use a ferule on the boost gauge,I have not checked on it but,I took my time on the install and I could be wrong but,I dont think its the install
Brain's 97 Diesel
29
06-24-2015 04:33 PM
