E40D Transmission removal
Old Apr 9, 2007 | 07:39 AM
hgufrin's Avatar
hgufrin
Hi all,
I have a 91 F150 with an E40D that I need to replace. Can I remove the transmission from the bottom or do I need to pull the engine.
If both which is easiest and least time consuming?
Thanks for your input
Old Apr 9, 2007 | 07:57 AM
jroehl's Avatar
jroehl
Out the bottom, and no, you don't have to pull the engine. You just have to get the truck up high enough to pull the tranny out the side. Linkages on the driver's side, electronics on the passenger side, driveshaft and crossmember in the rear, and bellhousing bolts in the front. You may have to undo your exhaust to some degree, too, to give you better access to some things.
Jason
Old Apr 9, 2007 | 08:00 AM
hgufrin's Avatar
hgufrin
thanks so much
Old Apr 9, 2007 | 06:31 PM
lostin90s's Avatar
lostin90s
Don't forget flywheel bolts . And remove starter
Old Apr 9, 2007 | 07:06 PM
XR400's Avatar
XR400
Might check these links. The guys over at the FSB forum have done a couple of really good write-ups with pics on dropping an E4OD. Really helped me anywho.
http://www.fullsizebronco.com/forum/...ad.php?t=52700
http://www.fullsizebronco.com/forum/...ad.php?t=48997
Old Apr 9, 2007 | 08:58 PM
brown 4x4's Avatar
brown 4x4
Depending on what you use for a jack, you'll have to get it so it sits flat on the jack. Due to the E4OD's hump in the pan, you may have to get some short 2x4's and a strap to keep it steady.
Old Apr 10, 2007 | 06:48 AM
hgufrin's Avatar
hgufrin
do you guys just crank the engine over to get every flywheel bolt?
it was a pain doing this when i drained the torque converter.
is there any easier way?
Old Apr 10, 2007 | 08:47 AM
jroehl's Avatar
jroehl
Yeah, slap a wrench on the crank and turn it by hand. Make sure you know which way to turn it first (I don't remember offhand, I always have someone bump the starter while I watch).
Jason
On edit: by "wrench", I mean something long like a breaker bar with a socket. A 1/2"-drive ratchet should be enough.
Ford Big Rig
Apr 14, 2017 06:07 AM
Kingkong0192
Jan 27, 2017 04:26 AM
Ceaumar
Apr 22, 2016 10:54 AM
cworley250sd
Sep 10, 2009 09:47 AM
Prplmnsterf150
Jun 3, 2005 08:16 AM
