e40d, screwed up and need help
Old Apr 22, 2016 | 10:45 AM
Ceaumar's Avatar
Ceaumar
So I wanted to replace the mlps and after I removed it I saw the shifter cable was in bad shape. I removed it as well, will replace it too. But in the process I moved the lever and now am not sure what position corresponds to what. Can someone tell me, if I am driver's side of the transmission, clicking the lever towards the front putting it in Park, or is it the opposite?
also, what position should it be when reinstalling the cable, and MLPS?
Cheers!
Old Apr 22, 2016 | 10:54 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
very easy to figure out.shift into park and watch to see if the cable lengthens or pulls right? then you'll know how it shifts from 1 to p.
when installing the range sensor (formerly known as the MLPS) line up the two lines on the sensor and have the trans shifted into N.
insure your wheels are chocked.
Ceaumar
May 11, 2016 04:52 PM
eduhat
Apr 9, 2016 03:12 PM
Blake Phipps
May 22, 2013 09:34 PM
Epd444
Apr 22, 2012 11:02 AM
mikekin1
Jul 25, 2007 08:46 AM
