Aerostar Ford Aerostar
Heavy duty alternator
Old Apr 5, 2007 | 10:00 PM
ganluin's Avatar
ganluin
Any body have any info on putting a heavy duty alternator on a 3.ol?
I am looking at putting in a second battery, marine deep cell type to power some additional equipment. I am also interested in information on charging multiple batteries off the alternator.
Any ideas and suggestions appreciated.
Thanks,
Gene
Old Apr 5, 2007 | 10:47 PM
96_4wdr's Avatar
96_4wdr
later Explorer 130 amp from wrecking yard fits if you have 3G alternator
or here
http://www.alternatorparts.com/Ford_3G.htm
Old Apr 6, 2007 | 12:33 AM
ganluin's Avatar
ganluin
Thanks for the info.
Gene
Old Apr 6, 2007 | 12:50 PM
ken1mod's Avatar
ken1mod
I would say to stay with the oem alternator unless you have problems. The output wiring and connectors are weak in these fords. They melt down pretty easily. If the stock one works, do not look for trouble, you will surely find it. The push on output connectors are a joke. Everyone else uses large bolt output terminals. Mine melted down with oem alternator.
Ken
Old Apr 6, 2007 | 01:59 PM
copper_90680's Avatar
copper_90680
Originally Posted by ken1mod
... The push on output connectors are a joke. Everyone else uses large bolt output terminals. Mine melted down with oem alternator.
Ken
Hi Ken:
What year is your Aerostar? On my '93 3.0L, the output is bolted onto the back of the alterator It's a pretty good sized bolt too!
Old Apr 6, 2007 | 02:33 PM
ken1mod's Avatar
ken1mod
Good for you, on mine it is two large spade connectors. Pathetic. they burned up and ruined the alternator and wiring. Must be bolted like Hoover dam generators.
ken
Old Apr 6, 2007 | 03:25 PM
Zen Punk's Avatar
Zen Punk
Well if he's going to install a battery isolator he's going to be running new cabling anyways.
Old Apr 7, 2007 | 01:49 AM
ganluin's Avatar
ganluin
This is still in the planning stages, to take place sometime this summer. What I envision is two seperate circuits so as Zen mentioned above, some kind of isolator for the additional wiring I will be putting in. I have seen a system on another forum where some people tricked out a 4 wheel drive truck with aditional battery and charging circuitry to run things like a whinch and lotsa lights and oter equipment.
I am not looking to be so radical, but do want to be able to power a pump for a DI water set up and some additional lighting with out draining my main battery. I could probably get away with stock, but want to do this for peace of mind. I don't want to finish a job and not be able to start my van.
Old Sep 17, 2007 | 07:39 PM
TheHandyman's Avatar
TheHandyman
I just now saw this post, the stuff needed for a 2nd battery with isolator, etc. is all available from Recreational Vehicle stores. It's common on an R.V. to have 2nd battery from the factory set up in this way. Should be easy to duplicate on an Aerostar.
Green96
Jan 3, 2014 12:51 PM
krewat
Modular V10 (6.8l)
15
Mar 7, 2012 09:32 PM
Downriver Thunder
Jan 2, 2009 07:56 AM
MdLake
Dec 15, 2003 09:26 AM
christop43
1978 - 1996 Big Bronco
Feb 28, 2001 05:19 PM
