Aerostar Ford Aerostar
leaky radiator
Old Apr 14, 2007 | 05:16 AM
xlt4wd90's Avatar
xlt4wd90
leaky radiator
My radiator seems to have developed a slow leak at the junction between the plastic tank and the aluminum core. I haven't pulled it yet, so I can't tell exactly where it is. I don't suppose it's possible to seal a leak in that area with some kind of goo?
I'm thinking of going my cheap route of finding a replacement at the junk yard. I'm hoping that if it isn't leaking, and doesn't look rusty inside, it might be worth trying.
Old Apr 14, 2007 | 10:18 AM
copper_90680's Avatar
copper_90680
Hi Eugene:
You might want to try the local radiator shop. I got a brand new Modine radiator for about $120. It was the 4.0L version with two-rows instead of the single row used on the 3.0L.
Old Apr 14, 2007 | 10:35 AM
Kruse's Avatar
Kruse
For the hassle involved, I wouldn't try one from a salvage yard. A month down the road, it will probably leak also. If you shop around, there are some good name brand radiators for a reasonable price, although it will probably be made in another country. Stay away from the goo-in-a-can leak fixers. It's a temporary band-aid and could possibly clog the heater core.
Old Apr 14, 2007 | 10:46 AM
Bear River's Avatar
Bear River
Former ******
If you want to go the cheap route, buy a new radiator and install it yourself. The seal tabs may help for a little while, but they can plug up heater cores, which cost even more to replace. The cheapest route is to properly repair or replace the radiator. Any other route leave you open to risks that it may fail and take out a head gasket from overheating. The cheapest route is to get a new one and replace it yourself. I've been down that road, and replacing a plugged heater core is not fun. I didn't replace it myself, because I don't have the time. It took the mechanics who worked on it six hours to replace it.
Old Apr 14, 2007 | 12:31 PM
ken1mod's Avatar
ken1mod
I have done the Modine replacement thing myself. It is nice knowing that the effort will bear a good result because the parts are new. Check around. I have paid 100.00 for a used part and found out later that a new part was nearly the same price.
ken
Old Apr 14, 2007 | 02:31 PM
bozzzz94's Avatar
bozzzz94
There are still deals out there because I just recently purchased an 2 row Modine for my 4.0. I won it off E-bay still new in the box for $ 40. Here is their web address out of Kansas City Misouri if anyone is interested.
www.midwayauto.com
Old Apr 14, 2007 | 04:33 PM
96_4wdr's Avatar
96_4wdr
xlt,
if you are planning on keeping the Aero as a dependable driver only a new radiator
an old leaker can quickly kill a 4L, 3Ls are more forgiving
Modine will last another 10+ years, cheap Chinajunke import=blowout on trip leaving you stranded????
Old Apr 14, 2007 | 04:42 PM
xlt4wd90's Avatar
xlt4wd90
I was thinking of using some kind of epoxy on the outside to plug the hole.
No response doing a parts search at Midway. But I'll continue to shop for a new one. Modine you say?
Old Apr 14, 2007 | 06:09 PM
96_4wdr's Avatar
96_4wdr
Proliance makes Modine
http://www.pliii.com/prod_radiators_auto.htm
FTE sponsor Rockauto carries....good internet source of Proliance
http://www.rockauto.com/catalog/raframecatalog.php
Old Apr 14, 2007 | 06:23 PM
copper_90680
Eugene:
If you happen to go down this way, let me know and I'll point you to the radiator guy I bought mine from.
Another thing about installation. The radiator drops into two holes on the bottom and is held by two bolts on top. The main reason a radiator will develop a leak at the seam is the twist incurred when you tighten the two bolts on top. If you put in some extra shims to eliminate that twist, the radiator should remain leak free for a long time.
Old Apr 15, 2007 | 02:13 AM
xlt4wd90's Avatar
xlt4wd90
Hi Tung,
That's good info. There does appear to be some looseness at the bottom that's allowing that area to shake a bit. Maybe the leak developed from shaking. I haven't found it yet.
I looked around for a replacement, and found a super heavy duty 3-row radiator that's supposed to fit in the Aerostar. It's made by a company called Pro-Select, but I can't seem to find a place that sells it.
Old Apr 15, 2007 | 03:36 AM
Kruse's Avatar
Kruse
Originally Posted by 96_4wdr
xlt,
I've got a radiator in my garage right that is waiting to be installed in my Aerostar. It is a Modine and it is made in Mexico. Like I said previously, just because it is a name brand, does not mean it is American made. Maybe the Mexican made product is better than Chinese, but it still does not give me too much confidence......
Old Apr 15, 2007 | 08:12 AM
96_4wdr's Avatar
96_4wdr
Modine builds for OEM, the original radiator in your van was probably Modine....Ford has not made radiators in 30 years....about the only parts manuf. in Ford plants anymore is the major body sections, engine assemblys, most trannies....
most internal engine parts, ie cranks, pistons, cams....rear ends...suspension parts are outsourced to non Ford manufs...many in Mexico, some that Ford has a joint venture with
but all original parts in a Ford no matter who the manuf is meets OEM Ford specs
Ford also specs aftermarket replacement parts
Modine builds for both of these Ford specs and has been in Mexico for 10 years+
most of the Chinese do NOT and even print fake OEM certifications on parts and boxes
would you fly in a Boeing 767 with fake certified made in China parts?
Old Apr 15, 2007 | 11:46 AM
Kruse's Avatar
Kruse
No.
Would you fly in a 767 made entirely in Mexico?
My point is, both countries have lots of inferior parts and the name brand companies are cashing in on it.
Old Apr 15, 2007 | 04:52 PM
ken1mod's Avatar
ken1mod
I replaced many Harrison , made in America, radiators with modine with flawless results. We know full well how to build junk too. Sad, but true.
ken
