Driveshaft question??
Old Apr 5, 2007 | 09:17 PM
FORDguy360's Avatar
FORDguy360
I had a driveshaft made for my 74 F100 stepside shortbed not too long ago and finally got around to installing it. Ran into a problem though. Where the U joint on the driveshaft connects to the differential, the bearing caps that were put on the driveshaft do not fit. They are too big. The straps do not fit around them. My question is can those bearing caps be replaced with smaller ones? Is it that simple?
TIA
Jake
Old Apr 6, 2007 | 05:40 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FORDguy360
I had a driveshaft made for my 74 F100 stepside shortbed not too long ago and finally got around to installing it. Ran into a problem though. Where the U joint on the driveshaft connects to the differential, the bearing caps that were put on the driveshaft do not fit. They are too big. The straps do not fit around them. My question is can those bearing caps be replaced with smaller ones? Is it that simple?TIAJake
There are three different sized U-joints used originally on these trucks. 1280, 1310 and 1330. If your truck has a 360, it would prolly have had the 1310 size front and rear. Did you buy new u-joints, and if so, are they the same front and rear? You will need to determine what size the joints are. If the ones you now have are 1330's, it's possible to buy a joint that has two 1330 caps and two 1310 caps.
JagerBlunt
Aug 17, 2013 09:27 PM
Newcomer
Offroad & 4x4
61
Apr 22, 2011 10:05 AM
highboy1979
16
Feb 15, 2009 03:15 PM
someday
Jun 14, 2007 10:09 PM
rokhopper
1983 - 2012 Ranger & B-Series
Jun 26, 2000 07:01 PM
