Never have had to remove one, so I don't rightly know how to do it.
Have had them stop up on me though, from deposits remaining from using low quality washer fluid & mineralized tap water.
If your problem is that it's sorta stopped up, try unwinding some small dia braided, or twisted wire rope & use one of the small stiff steel strands, to poke into & open up the spray nozzle. I've had to do this twice on my 94 Taurus.
Now I use better quality washer fluid & only mix with distilled water, or my home AC condensate, which I save, for that & all sorts of other things!!!!
