Universal Windshield Washer Kit
Old Oct 26, 2011 | 08:38 PM
Chea77F150's Avatar
Chea77F150
I hate to do it but my original windshield washer tank has a hole in it and the motor is out. Has anyone used a Universal Windshield Washer Kit and liked it? I need something to get me through the winter, have been driving my truck for the last few years without washer fluid and have needed it pretty bad in some situations.
Thanks!
Old Oct 26, 2011 | 09:16 PM
fmc400's Avatar
fmc400
MSEE
If you don't turn up much luck going that route, the pump is pretty cheap and easy to find. You might be able to patch the tank with JB Weld. I successfully patched a lawn mower gas tank with that stuff; not sure why it wouldn't withstand washer fluid. This is the route I would go, personally.
Old Oct 26, 2011 | 09:25 PM
kingford72's Avatar
kingford72
you can go pick up a later 80-96 ford truck washer tank, it uses the same motor and you get a coolant catch too, it'll fit on the flat spot on the driver fenderwell too.
Old Oct 26, 2011 | 09:40 PM
JB78f150's Avatar
JB78f150
I second this, I did this in all the trucks I own and have owned.
Old Oct 27, 2011 | 06:35 AM
i-w's Avatar
i-w
get one out of a 80's or 90's bronco
even the plug is the same. just extend the wires a little.
plus now you will have an over flow catch for your radiator.
the reason for the rubber strap was because the tabs to mount it were all broken off.
Old Oct 27, 2011 | 09:00 AM
460me's Avatar
460me
While you are at it,put a wiper delay switch in there if you don't already have it.All plug and play
Old Oct 27, 2011 | 02:27 PM
Chea77F150's Avatar
Chea77F150
Thanks!
Thanks a lot guys! I will go ahead and find one of those tanks!
Old Oct 27, 2011 | 04:42 PM
RKDxpress's Avatar
RKDxpress
I saw a rig with a ten gallon sprayer plumb in. It cleared mud and more from the windshield. This is what I plan on doing soon. Est cost about a hundred. But worth it after seeing it work.
Old Oct 27, 2011 | 07:13 PM
EffoneHunded's Avatar
EffoneHunded
like i-w i have mine mounted to driver side of radiator. on the bronco i took this tank off of there was a hard plastic pipe with a rubber elbow that goes to the washer side of the tank i would also get this. the washer fluid hose on our trucks is smaller than the hose that fits these tanks but the plastic pipe will allow you to fit the smaller hose to the tank without having to purchase anything else (by way of shoving).
mid 90s truck/bronco tank
click to enlarge
Old Oct 27, 2011 | 07:18 PM
TOPHER1978F150's Avatar
TOPHER1978F150
I have an extra good used stock one I'll sell you. I'm not sure if the motor works but the tank is in nice shape. PM me if you are interested.
Old Oct 28, 2011 | 04:43 AM
nlareau's Avatar
nlareau
Me too. Worked great.
Old Dec 21, 2011 | 01:27 PM
shawgf's Avatar
shawgf
I will do this conversion later with the tanks, My pump stopped working the other day. Is the original pump located on the tank? and can i buy a new pump at most auto stores.
Old Dec 21, 2011 | 01:38 PM
jsutton's Avatar
jsutton
Awesome!!! I've never heard of this!!! I will be doing it for sure!!!
I had to remove my original washer tank when I did the serpentine belt upgrade and used the newer power steering pump because the the pressure line needed to go right where the original washer tank was.
Old Dec 21, 2011 | 02:51 PM
Scallop's Avatar
Scallop
I put one of the universal jobs in the other week. It works, but doesn't hold much, and doesn't sit in the engine compartment too well. I would recommend against them if you're able to avoid it.
Old Dec 21, 2011 | 04:26 PM
Discovery's Avatar
Discovery
If the original OP does not take this I will, Have PP standing by.
drasm22
6.4L Power Stroke Diesel
Aug 7, 2017 07:05 PM
BOBFIDY
Jul 11, 2016 08:00 PM
Chevmn56
Mar 25, 2013 04:22 PM
Ken_C
Feb 16, 2011 08:53 PM
Wilbert
1997 - 2003 F150
Dec 24, 2009 06:51 AM
