1978 - 1996 Big Bronco
79 bronco 4-wheel drive
Old Feb 13, 2002 | 11:50 PM
paulpete65's Avatar
paulpete65
can any one tell me the correct way to engage 4-wheel drive in my bronco. I seem to be doing something wrong it will go into 4l or 4h but with you have to work it. is could this be because of low fluid. It is easier when I change the fluid.HELP
Old Feb 14, 2002 | 12:28 AM
christop43's Avatar
christop43
My cousin had a 78, and my friend had a 79, both of them had to muscle it into 4wd. Maybe there was a problem with theirs too, but it seems to come with age. just my thoughts though.
Old Feb 14, 2002 | 11:11 AM
jopey's Avatar
jopey
I have a 78 and it shifts very easily into 4wheel drive.
Please explain how your doing it. Are you moving? are your hubs locked in? Do you have auto hubs? Is it grinding?
Old Feb 14, 2002 | 11:36 AM
hillbillyk's Avatar
hillbillyk
sometimes it helps if you ease it foreward, or backward when you are putting it in, or taking it out of 4x4.
Old Feb 14, 2002 | 12:35 PM
AlM's Avatar
AlM
as Hillybilly stated..and do you lock the hubs first, then shift?
..and..have you cleaned the linkage to the t' case? our 78 did get muddy and gunky
..changing the t case fluid is good too, esp if you think it needs it; check the vent too for crud; and any leakage around the case, etc.
Old Feb 15, 2002 | 11:18 AM
paulpete65's Avatar
paulpete65
I first lock my hubs then start trying to shift. at times I do ease it forward or bacward to get it in gear.
Old Feb 17, 2002 | 11:17 PM
jeandras's Avatar
jeandras
Post 79 bronco 4-wheel drive
I got a 79 bronco and what i do is lock the front hubs and move forward a little while still in 2wd. Then i put it in neutral and it shifts just fine. Sometimes you have to go one way before you go the other. when i try to shift in park it is harder so try neutral. When disengaging you might have to roll a little also.
joseph
Old Feb 23, 2002 | 05:07 AM
frhoefer's Avatar
frhoefer
I always shift my 79 in neutral. It's almost impossible in park. I also have a grinding noise when decelerating down a hill at highway speeds when there is no force either forward or backward on the gears. Does anyone know what the problem is here?
Fred Hoefer
Old Feb 23, 2002 | 09:06 AM
Bob_VT's Avatar
Bob_VT
a_ford_truck_man
Apr 6, 2013 02:58 PM
TEXANFOREVER
Apr 29, 2007 01:00 AM
bulldog18
Dec 4, 2004 02:43 PM
bulldog18
Dec 3, 2004 04:39 AM
sherriehicks
Bronco II
Sep 10, 2003 12:54 AM
