1978 - 1996 Big Bronco
need some info
Old Apr 5, 2013 | 03:28 PM
a_ford_truck_man's Avatar
a_ford_truck_man
need some info
hey ya'll, im back on here with another question about my bronco. i just noticed that i am low on tranny fluid. my quetion is, is there a special tranny fluid i should use since she, (my bronco) is a four wheel drive? if any of yall can give me some advice on this i would greatly apreciate it. thanx
Old Apr 5, 2013 | 06:02 PM
greystreak92's Avatar
greystreak92
Fluid type will be engraved into the transmission dipstick along with fill indicators. Depending upon age of the truck it uses either Type F or a Mercon derivative. The T-case is filled with gear oil and is separate from the transmission.
(If you find a Bronco in the U.S. without 4WD it has been modified or imported. Ford did not produce a 2WD Bronco in the U.S.)
Old Apr 5, 2013 | 08:43 PM
Encho's Avatar
Encho
The Southernmost Mod
Which kind of gear oil do you run on the transfer case? my OM recommended ATF for it, mine is a electrically shifted BW1356, may that cause the difference?.
Old Apr 6, 2013 | 02:58 PM
gpence's Avatar
gpence
Same fluid you use in the tranny. Don't matter if its ele shifted or lever shifted still pretty much the same Tcase inside
Bearjew253
Sep 26, 2017 10:31 AM
tbugher62
Nov 6, 2014 03:54 PM
7278ford
Sep 18, 2009 02:27 AM
Rossta86
Feb 13, 2006 09:28 AM
Jrock909
Jul 30, 2003 01:50 PM
