I was just wondering, what causes a torque converter to whine when its going bad, do they whine if they are not going bad? It seems to me everytime I hear a "whiner" it goes bad in a year or less, "depending on the driver". I also had someone tell me that torque converters don't go bad that often, but for some reason I come across more fried converters than anyone I know.
1. how is that whining noise produced
2. can an out of adjustment tv cable ruin a converter
3. ?
is there any good sites that anyone knows of for trans that go beyond the basic operations "most just tell you how it all works I need specs"
thanks to all for sharing your thoughts and comments.
3. ?
1) The bearings in the stator are failing. Like any other timkin bearing, they whine as they fail.
2) Depends on the transmission. An AOD, which does have a TV cable, doesn't have a lockup converter. If the TV cable is out of adjustment it will overheat the transmission, which will kill the converter too just because of the heat and debris.
Converter bearing failures are somewhat rare. Most "converter whines" are actually pump whines. The pump whine is usually produced by the pump cavitating. That is the pump cannot draw enough fluid through the filter and creates voids where the fluid should be. That will kill a pump pretty quick. A pump whine can also result from the pump coming apart.
Appreciate the info. I just changed the trans two weeks ago.
My major concern was seeding the torque convertor properly.
If this was done incorrectly would it cause the whining?
What about changing the filter? would this help at all?
Is there an additive I can use to prolong the life of whining trans?
What about having the to pump changed (NOW) while all the other functions of the tranny seem to be working properly.
My truck is a daily driver.... about 22mi round trip. I have the extra large volume radiator installed... the temp needle stays on the N and O of normal throughout all driving ranges... will this help? I'm just low on cash now...
I need this tranny to get through to summer.
Boonie;
Was it a used or rebuilt unit? A used unit there is no telling what may be wrong but a rebuilt unit could easily have a converter with a bad bearing in it. The pump could be bad but the converter bearing is more likely on a fresh rebuild.
Again, depends on used/rebuilt. If new, I would drop the pan to see if there is metal in it. If so then something is failing. If its used, look for clutch material stopping up the filter. Changing the filter is a very temporary fix. The only thing that would stop up the filter is transmission parts. So if the filter is clogged, the clogged filter is the least of your worries.
If everything else looks good (no debris in the pan) change the converter instead of the pump and see if that kills the whine. If not, then its most likely the pump. That is assuming that the whine tracks with engine rpm and not road speed. A road speed whine is grear train.
Does it have an external cooler? They are always a good idea.
Metal in the pan would be the first signs. A bad pump whines because the gears are chewing into the pump housing. You should see aluminum debris in the bottom of the pan. AOD pumps are not a weak point but they do fail. An AOD pump failure is more comon because it was ingesting metal debris.
A converter bearing can make noise for some time before it fails. On a newly rebuilt converter it could be that a bad bearing was installed. If an existing converter begins to whine, then its probably a more impending failure as either the bearing is going to it ate something.
That should say, "doesn't have an electronically controlled lockup converter."
The AOD has a mechanically applied lockup converter. It locks 60% in third gear and 100% in fourth gear.
The converter doesn't have lockup at all. How do you have 60% lockup? It is either locked or it slips. A converter's slip is determined by load and stall speed.
