I accidentally broke the low pressure gage on my argon-co2 regulator the other day. THe tank tipped and the gage got bumped. I tried to get a new gage, but I am only able to find replacement gages for oxyacetylene or high pressure for 75-25. So the question is-what pressure in psi do you think converts to the cfh, and will a low pressure acetylene gage work for this application. ANother thought is that the gage still works, except the zero point is at about 50 cfm now, so I could make that a new zero. I would like to have a more accurate gage though, because the copper tubing in this one is kinked somewhat and I don't trust its precision at all.
If you want a more accurate gauge, get an actual bottle flowmeter. This uses the flow of gas to float a ball in a tube, and the gas must be flowing to set it. They automatically regulate the pressure to either 20 or 50psi.
Those gauge flowmeters actually are just pressure regulators, used with a fixed orifice to create the same general effect.
Expect to spend $75 or better on a real bottle flowmeter. http://store.cyberweld.com/smflreh11.html
