Dash Gages
Old Aug 12, 1999 | 10:32 AM
Chris Rogers
Guest
Posts: n/a
Dash Gages
Currently redoing my 64 F100. The original speedometer in the dash housed the gas level, oil pressure, and some other gages I can't remember. The questions are: 1. Has anyone used the original gage panel to mount new gages in (thus updating the gages in their truck from the stock all in one speedometer to something newer)? 2. Has anyone (and I'm sure someone has) made a wooden gage panel to replace the original aluminum one (thus allowing them to mount their own gages in it)?
Old Aug 12, 1999 | 11:29 AM
jowilker's Avatar
jowilker
Dash Gages
Chris, I think that the hardest thing is finding replacement gauges the same size. If you have the talent and patience then make you some wooden ones, it will be challenging.
John
Old Aug 16, 1999 | 01:22 PM
ole65's Avatar
ole65
Dash Gages
My 65 has a set of Stewart Warner guages; the tach and speedometer are a large diameter with the other four (fuel, temp, oil press and voltage) in smaller diameter guages. The stock outside metal bezel is used with a textured grey panel insert to hold the guages, the panel is about 3/16 " thick. Decorative bolts hold the panel to the bezel It must have been a kit since the edges are finished with this grey vinyl-type covering. From what I see (done by the previous owner) you would need to use thin veneered plywood or a composite product to avoid warping. I would suggest using tempered masonite with a real wood veneer glued over the final panel. That would allow you to also finsh the cut edges with veneer if you so wish.
Old Aug 19, 1999 | 10:10 PM
Randy's Avatar
Randy
Dash Gages
Im pretty sure if you look around you could find a chrome one...I own a 1963 SWB Unibody and i found it with the original chrome dash..I bought the truck with a nice little 292 v8 and 3sp st. for 1000....so if i was you i would check the salvage yards..good luck
Old Aug 20, 1999 | 08:30 AM
jowilker's Avatar
jowilker
Dash Gages
Chrome metal dashes are very rare, better time would be spent at truck shows and swap meets.
John
Old Jan 17, 2001 | 04:24 PM
skip4274's Avatar
skip4274
Dash Gages
Chris:
You didnt say if yu have th long plastic custom cab insert or not, but in the tech section there is an article that is just what you want.
Skip4274
4everFord
Old Jan 17, 2001 | 05:31 PM
Nate_64's Avatar
Nate_64
Dash Gages
Chris,
dakota Digital sells an LED display cluster that will fit into the stock hole. It also includes Speedo, Oil, amp, and gas all in the same cluster. It is listed as being for a bronco, but they are the same size. It is very pricey but you might want to check it out anyway.
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.yahoo.com/clubs/fordpickups61to66fseries
Old Jan 17, 2001 | 06:45 PM
hpguy's Avatar
hpguy
Dash Gages
How would something like this work?
https://www.ford-trucks.com/dcforum/User_files/3a664a656933cde8.jpg
You just cut out the circles on the sides, and add your guages.
On mine above, there is an oil pressure guage on the left, and an amperage meter on the right. This way you keep the original look, with modern conveniences.
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Jan 17, 2001 | 09:23 PM
StockMan's Avatar
StockMan
Dash Gages
Old Jan 17, 2001 | 10:45 PM
oldfordsidestep's Avatar
oldfordsidestep
Dash Gages
[font size="1" color="#FF0000"]LAST EDITED ON 17-Jan-01 AT 11:46 PM (EST)[/font][p]Andrew that is a very good look. I was thinking about doing that to my truck but I don't know what to use to cut the holes.
-Tyler
WQ59B
1947 and Older Ford Trucks
15
Mar 23, 2016 06:29 AM
CheckEngine
1983 - 2012 Ranger & B-Series
Oct 1, 2015 07:04 PM
dodmort
1966 - 1977 Early Broncos
Feb 20, 2013 08:14 PM
tigerflyer
Modular V10 (6.8l)
Dec 29, 2011 08:03 AM
bubbaredneck
Feb 6, 2002 07:58 AM
