Oil & Lubrication
Fram filters
Old Jun 25, 2007 | 12:50 PM
  #61
2000Expy's Avatar
2000Expy
I have used Fram, but have heard they are not the best. I think their price pretty much tell us about their quality.
Old Jun 25, 2007 | 08:47 PM
  #62
jimdandy's Avatar
jimdandy
At the Chinamart nearby, Motorcraft is cheaper than Fram. So what is that telling us???? Nothing other than they are both low cost filters. For better filtration it is said to use the premium filters. jd
Old Jun 25, 2007 | 11:36 PM
  #63
Ed's Avatar
Ed
Partsman, the HP-1 Fram and the PH8A oil filters are night and day difference. That's like comparing Spam to a Angus Beef Steak.
Old Aug 30, 2007 | 04:09 AM
  #64
fordmtnman's Avatar
fordmtnman
I've gone my whole life up to this point without considering the possibility that my filter is counterfiet. No one has ever suggested to me to go buy a bunch of new oil filters and cut them open... maybe the next time I have fifty dollars, and I can't think of anything else to do with it...
Gotta say, I've gone my whole life and not had a fram fail. Never HEARD anything bad about them until I saw this. Not that I'm brand loyal - I've just never considered it.
The only motorcraft experience I've had is with the filter on my truck (2000 miles) and on a number of spectacularly lousy carbeurators.
Old Aug 30, 2007 | 12:21 PM
  #65
MScotty's Avatar
MScotty
Fordmtnman is right in a way. I too HAD used Fram filters with never a problem, and if I hadn't seen all the negative (right or wrong) things said about them I'd still be using them. And may never have a problem.
But the human mind is a strange creature, enough people say something is bad and it becomes bad. Again Right or Wrong?
And I have to admit, I'm one of them. But mostly because I cut one open and didn't like what I saw. Mainly because the pressure relief valve is not build into the filter end cap (I know some are at the other end too) itself, it's part of the leaf spring that holds the filter element against the fitting end. So there is no real seal between that and the filter element, just the spring pushing it against the cardboard end cap.
Old Aug 30, 2007 | 06:11 PM
  #66
Melchiah's Avatar
Melchiah
SPAM is a delicasy in Hawaii FYI
and second i had a fram crap out on me once and they paid for the repairs there was some plastic valve in the filter and it wassn't cut out all the way or something and ya my motor got no oil after the change and i have never used a fram since, but i also understand that nothing is 100% perfect off an assembly line there are defective products
Old Aug 31, 2007 | 08:49 AM
  #67
mrxlh's Avatar
mrxlh
You know what they say, tell a lie long enough, often enough, and hard enough, and it becomes truth.
Old Sep 9, 2007 | 12:25 PM
  #68
fordmtnman's Avatar
fordmtnman
I tore up the internet researching this, and when it's time for my 1st oil change in a couple weeks, I think I'm going to go with the Bosch oil filter and Mobil 1 Synthetic.
I will miss the fram cases with the grip strips around the end cap so you can hand tighten/loosen them...
Old Sep 10, 2007 | 02:34 AM
  #69
Ed's Avatar
Ed
Any oil filter is easy to tighten by hand, as long as the gasket is properly coated with a film of fresh oil.
Removing the oil filter, should never be a problem either. Oil filters do not need to be torqued on tight. Snug, but any common oil filter wrench will remove it easily. Especially when you change the oil filters yourself, there never is a problem.
Over-tightened oil filters, as done by various 'quickie lube' joints, then I can see why having that rough black strip on the edge of Fram filters would come in handy. Or an oil filter covered in dust, dirt, with a oil haze. The oil filters on my cars never get that way, even in my beater Escort I keep the engine clean - degrease and clean it once a year whether it needs it or not.
I am surprised no other company came up with that idea. I'll even say that was one of Fram's better additions to their orange bullets.
IDIDieselJohn
27
Mar 24, 2011 11:33 PM
shade1965
Feb 28, 2010 11:27 AM
kdbbmanton
2004 - 2008 F150
Sep 22, 2009 06:18 PM
rblomquist
Aug 29, 2005 09:31 PM
motorguy222
Oil & Lubrication
26
Sep 4, 2004 04:49 PM
