Check Gages Code P0713
Old Mar 31, 2007 | 12:35 AM
03KingRanchF250's Avatar
03KingRanchF250
Well while driving my truck i noticed my tow/haul light flashing on the shifter, then noticed CHECK GAGE Light in dash. well i pulled the code and it read "P0713 Transmission Fluid Temp. Sensor CKT High Input" The trans temp gauge on my dash reads spiked to the max. I have autometer gauges and one being a trans temp which reads from 150 to 160 normally and is reading that as the stock gage is pinged out to the max. Is the problem just a bad sensor? What does ford charge to change it and is it covered under the 100k mile warranty? Everything seems to be driving fine but the dash light and flashing tow/haul button is getting really annoying. any help would be appreciated.
Old Mar 31, 2007 | 04:47 AM
npccpartsman's Avatar
npccpartsman
Definitely sounds like a bad sensor to me. Have you tried returning your truck to stock parameters to make sure it wasn't the 1805 causing issues??? You should do that before taking it for repairs to make sure it isn't messing with the TCM
Old Mar 31, 2007 | 08:03 AM
BowTieHatr's Avatar
BowTieHatr
9 times out of ten, with your description it will be a sensor. the early sensors was not that bad, but we still had many that would do what you did. if you dont mind getting your hands dirty, do it your self. it is not that hard. you will have to drop the pan and the sensor is at the right front of the valve body area where the dipstick comes in at. and unless you have extended warranty, you are out of luck.
Old Mar 31, 2007 | 11:45 AM
03KingRanchF250
Thanks guys for the help. Always like getting quick answers from this site.
Old Mar 31, 2007 | 01:25 PM
a-rod's Avatar
a-rod
same thing happened to my truck, It also made it shift hard and wierd, they changed the sensor and all was good.
aaronbrace
Feb 3, 2023 10:18 AM
94L03X
Mar 18, 2016 09:06 PM
kx450frider617
Mar 20, 2013 11:46 PM
Dominating
Jun 16, 2012 05:21 PM
Nathan
Dec 2, 2010 04:53 PM
