#14 error code need help understanding
Old Mar 30, 2007 | 01:35 AM
spike552's Avatar
spike552
1987 f160 inline 6, truck keeps stalling, wait 20 mins then runs. I had a tested hooked in so when it did die i could start the test asap and got code #14-Two or more successive erratic Profile Ignition Pickup pulses occurred, resulting in a possiable engine miss or stall, i have no clue on what the hell that means i need direction am i looking at spark plugs timming plz help.
thnx in advanced
p.s. How do u read error codes with a 0 in it, Exmp 10,20,30
Old Mar 30, 2007 | 04:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
thnx in advancedp.s. How do u read error codes with a 0 in it, Exmp 10,20,30
I have no klew how to read codes, but know enough about Fords to tell you this has to do with the pickup coil (stator) in the distributor. The pickup coil and the ignition module work together and both could be defective. The coil is used with EEC IV. When these begin to fail, the vehicle will stop dead, then later restart...run a bit and then the entire process repeats itself. Eventually the vehicle will die and not restart.
Ford had a recall on these two parts several yrs ago (5 million were recalled!). They had problems with these two parts since 1984, the first yr for this module/coil. I'd check with the dealer to see if your vehicle may be covered.
E5PZ-12A112-A .. Pickup Coil (stator) (Motorcraft D-U-30-A)
E43Z-12A297-A .. Ignition Module (Motorcraft DY-425)
You will need a slim shanked Torx wrench to remove the ignition module, which bolts to the dizzy body. The coil is under the dizzy cap, in plain view. Make sure you use the dilectic grease that comes with these two parts.
Old Mar 30, 2007 | 11:18 AM
spike552's Avatar
spike552
I thank you for your help, you have been most helpful one more question, would this problem become worse in 90 deg outside air and imagine engine compartment air. I gotta say it does seem like its getting worse, used to be one heavy heat, but it was 30 deg out last night and i was stuck out by the landfill go figure. Thnx again man
Old Mar 30, 2007 | 05:32 PM
spike552's Avatar
spike552
Is there any way to remove the stator without removeing the entire distru entirely.
Old Mar 30, 2007 | 10:30 PM
F150xlt's Avatar
F150xlt
There are no codes that contain a zero for your truck.
Yes the distributor shaft has to be removed to replace the pickup.
A rebuilt distributor which includes a new pickup costs around $60.00 with your old one as a core.
A rebuilt distributor including a new TFI module is around $110.00.
Here's a picture of the pickup coil.
Old Mar 30, 2007 | 10:36 PM
NumberDummy
Heat is the enemy of these dizzy mounted ignition modules. As I said in previous post above, the E43Z-12A297-A modules were crappola from the get go. I prolly sold over a thousand from 1984/97. Over 5 million were replaced in recent recall by Ford. Never, ever buy a rebuilt module. Most are fresh from a wrecking yard, and are cleaned off and tested, and a tag that states"rebuilt" applied. Usually found in fly by night parts houses....the same outfits that sell "rebuilt" starters and alternators for $15.95 and up. Same process for "rebuilding" these is used. Wiped clean, sometimes repainted and maybe bench tested...parts replaced only if absolutely necessary.
Old Mar 30, 2007 | 11:03 PM
spike552's Avatar
spike552
Taking this in like a spung thnx guys, ran into a problem, i have the tfi and the pick up didnt cost me alot at all at advanced but i was un able to remove the distributor from the engine, it just wouldnt move in any direction is there something iam doing wrong here, put everything back together just fine, wokrs for me just something new to learn about ehh.
Old Mar 30, 2007 | 11:37 PM
F150xlt's Avatar
F150xlt
At the base of the distributor there is a 1/2 bolt and clamp
that holds the distributor in place. Remove the bolt and clamp.
Then pull up on the distributor.
You need to note the position of the distributor
base in relation to a fixed object and the position of the rotor for
proper reinstallation. You will also need a timing light to verify
proper timing.
Old Mar 31, 2007 | 10:46 AM
HunterSThompson's Avatar
HunterSThompson
Pulling the dizzy is a snap, just mark where the rotar is pointing PRIOR to loosening and make sure the engine dosen't get turned until the dizzy goes back in - pointint EXACTLY where it was before.
Old Mar 31, 2007 | 07:06 PM
spike552's Avatar
spike552
My problem is that when i losen everything and the hold down bolt, mark the base to the engine and get rdy to pull it out, it doesnt want to come out, i have tried a little force but i dont want to try to much if something is gonna break.
Old Mar 31, 2007 | 07:24 PM
HunterSThompson
Wiggle the rotor - sometimes that helps.
Old Apr 1, 2007 | 02:17 AM
spike552's Avatar
spike552
Just want to be clear here, telling me i wiggle the rotor and the distibutor will come out, sry i just want to be absolutly sure bout everything.
Old Apr 1, 2007 | 07:32 AM
HunterSThompson
My psychic powers hat is out for repair - I am unable to tell you what will work - but I will try with what has worked for me in the past.
The dizzy will rotate but stays firm when you tug upwards right?
If so then,,, Wiggle the rotor while lifting gently.
It SHOULD help lift the dizzy housing by using the helical gears that connect the rotor with the camshaft
Jack Ewy
Aug 21, 2016 05:48 PM
leannacarol
2004 - 2008 F150
Jan 4, 2016 07:02 AM
cbrown_63
Nov 21, 2010 09:24 AM
raptor2005
Feb 15, 2010 03:03 PM
kilted_drummer
Escape & Escape Hybrid
Jan 15, 2009 01:07 PM
