How do you remove the 4x4 dash switch?
Old Mar 28, 2007 | 10:15 PM
jtharvey's Avatar
jtharvey
Disregard this thread
Edit - I figured it out. Please disregard this thread. I can't delete it...maybe the mods can.
Old Mar 29, 2007 | 03:57 AM
ryaneverk2's Avatar
ryaneverk2
You should post your findings here for future reference, Jeremy.
It's just a pull-and-yank, right?
Old Mar 29, 2007 | 06:22 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Unclip/pull out the entire dash assembly and it pushes out from behind. Don't pry on the plastic from the outside there are detents that need to be depressed.
Old Mar 29, 2007 | 06:39 AM
Kwikkordead's Avatar
Kwikkordead
Would this be a similar motion as removing the headlight switch? Push the locker to the right before you can pull it out?
Old Mar 29, 2007 | 08:14 AM
jtharvey's Avatar
jtharvey
Two small tabs on each side, about 1/4" - 1/8" from the top and bottom. I moved the switch to the left side, put a small screwdriver in from the bottom on the right side and carefully depressed the tab on the bottom then top of the right side. Once the right side was free, it slid right out. Patience is the key here. Oh, and I managed to not break it.
Old Mar 29, 2007 | 08:21 AM
Uzumati's Avatar
Uzumati
uhmmm, Why are you removing the switch..........What are you brewing up?
Old Mar 29, 2007 | 09:06 AM
jtharvey's Avatar
jtharvey
Nothing major. I'm using the location beside the 4x4 selector to mount a switch that will activate my giant ape.
Old Mar 29, 2007 | 09:22 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
I mounted a light up back up ( for my auxillary lights) switch just below the 4x4 in that cover. Looks really cool.
weman818
13
Feb 13, 2012 08:08 PM
SCBarger
2004 - 2008 F150
Jan 15, 2012 07:24 AM
ekers88
Engine Swaps
Jun 24, 2004 09:25 PM
ford4x4offrd
Jul 14, 2002 10:53 AM
Ultramagdan
1997 - 2003 F150
Oct 25, 2001 08:30 AM
