frozen distributor
Old Mar 27, 2007 | 03:20 PM
nucleartruck's Avatar
nucleartruck
frozen distributor
I have a 79 f250 460 cid 2wd. I tried to adjust timing but distributor doesn't move after loosening the "hold down" bolt. Is it possible to break loose?
Old Mar 27, 2007 | 03:24 PM
Bear 45/70's Avatar
Bear 45/70
I spray the dist. base with PB Blaster, let soak then use the biggest pair of water pump pliers I have and twist that sucker.
Old Mar 27, 2007 | 09:08 PM
JBradley500's Avatar
JBradley500
mine was locked and i sprayed it wil PB blaster and let it sit...then i got a 1x1" piece of wood and a small hammer and tapped it back and forth until it broke loose.
Old Mar 28, 2007 | 06:05 AM
79superduty's Avatar
79superduty
I wrapped a chain around one and used a cherry picker, I had the wheels off the ground and it still didnt come out. a couple smashes with the hammer and then she slid out ....Yea ,I had to replace it....
Old Mar 28, 2007 | 07:04 AM
nucleartruck
Wow
Thanks for the advice. I plan to get the PB Blaster and give it a whirl!
Old Mar 28, 2007 | 07:28 PM
WILDEBILL308's Avatar
WILDEBILL308
I tryed that but it didn't work so I did the obvious thing and got a bigger hammer. Finaley got it to move and tapped it back and forth spraying liberley with PB till it came out.
Bill
79fordrat
Oct 21, 2012 04:13 PM
64fordf100292
Mar 16, 2007 04:11 PM
mwilbourn
Jan 26, 2005 01:19 PM
nevereverquit
Dec 29, 2003 06:59 PM
